Corner Weld Jigs
vanhulagen
Corner Weld Jigs
Post by vanhulagen »
corner welding jigs i drew it for 3/16
corner1.dxf
corner2.dxf
corner3.dxf
oldironrep
Re: corner weld jigs
Post by oldironrep »
Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
Scratch
Post by Scratch »
oldironrep wrote:Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
Here's a good video on a build of a similar one.
https://m.youtube.com/watch?v=_-JlHM_EWf4
Bradley
Post by Bradley »
Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
vanhulagen
Bradley wrote:Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
thats what i wasgoing to do just weld the outside off the tabs and maybe tac the ends
vanhulagen
hears in adjustable one
cornerajust1.dxf
cornerajust2.dxf
cornerajust3.dxf
motoguy
Post by motoguy »
These should come in handy. Thanks!
TimP
Re: Corner Weld Jigs
Post by TimP »
Thank you for the share!
A nice addition to the welding table.
Tim
techno
Post by techno »
Thanks for sharing.
BILLETMAN
Post by BILLETMAN »
thanks guys great ideas
james.davis
Post by james.davis »
look up back step welding
Jim
Capstone
Post by Capstone »
I made up a pair of these... thanks for the share. check out my Instagram for a pic.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
steel 35
Post by steel 35 »
Shaweet
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
steel 35
Post by steel 35 »
Except know I need a scribe!
Never mind I have one in the mail :lol:
Thanks Plasmaspider
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
fasteddie
Post by fasteddie »
Thanks, I have been wanting a set of these.
fasteddie
Post by fasteddie »
Thanks, Very nice.
4eleven
Post by 4eleven »
Cool, thanks guys!
xring
Post by xring »
I've been meaning to draw up some adjustable ones, now I don't have to! Thanks.
Bill
ETCWeld
Post by ETCWeld »
Thank you for sharing this
Davewynes
Post by Davewynes »
great files cheers for the share
Kentuckyfarmer
Post by Kentuckyfarmer »
Thanks for the files, I think the adjustable one has many uses may find a spot on the surface grinder table
inthemountainsmatt
Post by inthemountainsmatt »
Thanks for the share i just made a bunch of squares myself!
CGT80
Post by CGT80 »
Thanks for sharing!
The last one looks like the certiflat kits that I bought, which I really like.
Edit: I found your other thread and grabbed the file for those. It will be great to be able to make more and save some money.
Jeepguy32
Post by Jeepguy32 »
thanks for sharing!
mardybum
Post by mardybum »
Thank for sharing, the adjustable one looks like it will definitely come in handy, I may have to get 10 or 12 of those cut
