Straight Line\test cut Files
Have not learned how to draw yet, does anyone have any simple straight line test files lying around?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Re: Straight Line\test cut Files
I'm sure one of us can whip some up for you if you know what you're looking for.
Do you have length/width in mind?
What software are you using?
Here's a file I used when I set up my machine, saved in svg and dxf formats.
PPLLC 4X8 table w 620 ox steppers on 5 axes
Bladerunner CandCNC w/DTHC II
Hypertherm PM85
Hypertherm PM85
To get your feet wet download Inkscape (free) many tutorials on the web, easy to use. When you have a shape you want to try save it as a DXF or SVG to a folder then pass it through SheetCam (read both file type) to create your g-code. After you see how things work the get a CAD program for other types of drawing (brackets, parts, with precise dimensions ). there are a few free ones (QCAD and others). Pick one and start to learn it don't jump around with different programs.
Awesome Thank You! I have Inkscape, Sheetcam and Qcad, have messed around with Sheetcam but not the others yet, but will soon! Thank you again!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
I sent you a PM tylerd about Inkscape
