Weld Jig
Weld Jig
Here is a weld jig I put together. Have had some interest in it.
- david jordan
Re: Weld Jig
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Re: Weld Jig
Thanks for sharing!!!!!!!!!!!!!!
Re: Weld Jig
Thanks, looks great
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
Re: Weld Jig
Here's mine before clean up.
Re: Weld Jig
Thanks for the share What size metal did you use
Re: Weld Jig
thank you !
Re: Weld Jig
thats awsome.ive been wanting to build a table just hadnt had time.thank you
Re: Weld Jig
Thanks for sharing
- ETCWeld
Re: Weld Jig
Thank you for this
Re: Weld Jig
Thanks Just starting out and this will help
Re: Weld Jig
Great Share Thank you
Re: Weld Jig
Daddude wrote:Here's mine before clean up.
Was that cut with plasma?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Re: Weld Jig
Thanks for sharing
