Here's a Great Dane sign that my wife had me throw together for her sister for Christmas. I hope to cut it this afternoon, but everything looks good to me so far. The dxf has the sign blank. If it doesn't open correctly, please let me know - the last file I shared ended up having a bunch of missing lines, so I played around with my export settings until this opened correctly in Inkscape.
Tim
Great Dane Sign
Great Dane Sign
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Re: Great Dane Sign
thanks for the share
- david jordan
Re: Great Dane Sign
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Re: Great Dane Sign
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
Re: Great Dane Sign
Thanks for the share. Have been trying to join a name into this and it is kicking my butt. Usually never have a problem doing this, buy keeps showing one object not a path.. Lost..Suggestions.
Re: Great Dane Sign
What software are you working with?
I opened it in Corel and I would not have been able to add a name before joining all the broken segments that make up the design.
Once I joined all the segments I had to be sure the rectangle opening where the name was to be was "cut" out of the main design and not just a rectangle on top of the design if that makes sense to you.
With that rectangle being an "opening" in the main design I was able to add text and weld it to the main design.
Re: Great Dane Sign
Inkscape. Seems to open and look ok in sheetcam, but back to Inkscape, node nightmare. Would appreciate any and all help
Re: Great Dane Sign
Thanks for sharing.
I'll be cutting two of these for two different friends.
