I'm new to the board, only had my Super Bee set up for around a month. Designed this with some things I found around here. Thanks to all of the folks who designed the different parts. This is my first attempt at attaching a file. Hopefully it works. Cut it with plasma. No major burnouts that caused problems. a couple of things in the microphone, but it worked fine.
Blue Grass themed sign
Re: Blue Grass themed sign
Here is a picture.
Looks great even if the pic is upside-down
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
