I just put an adjustable gantry crane system in to move steel onto the table and then realized I would need to get some clamps. I had some small pieces of 1/2" in the shop so I decided to make my own.
My crane can handle 1000lbs so that was my design target. I don't/can't/won't warranty that this design will handle that -- but everything is spec'd to be on the beefy side. I modeled the design on many I had seen on the web that are similar.
I used 1/2" for all the parts. I welded the small piece between the cheek plates. This makes the underside of the clamp one solid component...
I was very pleased how cleanly the 1/2" steel cut on the table:
Here are various pictures of the clamp as built:
As attached to the gantry:
The DXF files are in 3 components - the side cheeks, the clamp arm ad the small anvil that I welded in. I used a 1/2" grade 8 bolt to hold it together.
Again - if you are worried about load limits and want to rant on this - please don't, just don't build this. If you find it useful and it will save you 120$/clamp - great!
Here are the DXF Files
Crikey - the site isn't letting me add the other files. Let me know if you are interested...
Horizontal plate lifting clamp
GEON, on the left coast...
Arclight Dynamics 6000 Pro 5x5
Hypertherm 65
Hypertherm 65
Re: Horizontal plate lifting clamp
Thank you. Nicely engineered.
Here are the rest of the files...
Hypertherm 65
Hypertherm 65
I have not built my lift yet. When I do I will be back for the files. THank you so much, I was wondering how I was going to create those.
These look perfect, I will scale them down a bit as I only cut up to 1/4 inch.
- rdj357
I have a set made from 3/16 plate that I've lifted half sheets of 3/4 with so I'm going to say your design is more than capable!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- Cz_apie
Hi Geon
Thanks for sharing, I will make me some for sure
Deon
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
- johnp
Nice share. Thanks!
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
I like your design. Thanks
