LED garden flowers
LED garden flowers
Here is a led garden flower. Flower and leaves are cut from 16ga cold roll and the stems are just rebar. I roll the leaves and petals with a small roller.
Re: LED garden flowers
Sorry for the extra post, learning how to post pics and files.
Those are really nice! Thanks for the file.
- kgc1031
very nice? what kind of paint did you use? is it possible to get you post in dxf file?
Down load Inkscape.kgc1031 wrote:very nice? what kind of paint did you use? is it possible to get you post in dxf file?
Import the cdr file into Inkscape
view - outline
save as dxf
Dave Hanks
- yeomansjon
Wow, these are really nice and a great idea. Thank you.
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
www.facebook.com/fastjonnycustomdesign
CNC Plasma Cutting
Plasmacam DHC
Thanks for posting learned something thanks to DXF the .CDR file swill open in Inkscape
Sorry here is the dxf
nice. thanks
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Thanks for the file. How are the lights attached?
Thank you for the file, it came in very handy when I removed the fruit tree and I was told that I would have to replace it with something!
Cheers Johno
Cheers Johno
Hot Glue. Very late on the reply sorrylik2waterski wrote:Thanks for the file. How are the lights attached?
How are you attaching the Rebar?
This will be a great file. Thanks
where did you get the lights? The flowers look good
Am I missing something? pictures are all showing overlapped pedals but file doesnt look that way? Nice work though!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinery!
-PM 85
-Miller Dynasty 400
He said he uses a small roller. I assume that a sheet metal slip roll?
When you roll the leaves they will overlap each other. Yes I use a small slip roller for the leaves.
I get the LED lights from your local home improvement store or you can order online but I like the see what I am getting when buying them. A bit more expensive but you can get them for $1-$2 at depot or menards
Lights are hot glued to the painted finished flower. I weld the leaves to the rebar and paint them, then on the bask of the flower I weld a small piece of pipe about 1" long for the rebar to slide into, Makes it easy for winter storage since you can remove the flower from the stem.
Thanks for sharing. I'll give these a try.
Is this they type of light you used? Do you just remove the stake and glue the top portion to the flower? It isn't apparent from the pictures if the center sticks up out of the flower.
Yes that will work. I use a larger domed light so I get more light effect. I just cut the part where the stake goes into off and hotglue the light to the flower. This is just a sample photo of the type I use.
