LED garden flowers
DaveRad
LED garden flowers
Post by DaveRad »
Here is a led garden flower. Flower and leaves are cut from 16ga cold roll and the stems are just rebar. I roll the leaves and petals with a small roller.
large daisy.cdr
DaveRad
Re: LED garden flowers
Post by DaveRad »
DaveRad
Post by DaveRad »
DaveRad
Post by DaveRad »
Sorry for the extra post, learning how to post pics and files.
Countrylane
Post by Countrylane »
Those are really nice! Thanks for the file.
kgc1031
Post by kgc1031 »
very nice? what kind of paint did you use? is it possible to get you post in dxf file?
DXF
Post by DXF »
kgc1031 wrote:very nice? what kind of paint did you use? is it possible to get you post in dxf file?
Down load Inkscape.
Import the cdr file into Inkscape
view - outline
save as dxf
Dave Hanks
yeomansjon
Post by yeomansjon »
Wow, these are really nice and a great idea. Thank you.
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
Thanks for posting learned something thanks to DXF the .CDR file swill open in Inkscape :)
DaveRad
Post by DaveRad »
Sorry here is the dxf
large daisy and leaves.dxf
K D Metalwerks
Post by K D Metalwerks »
nice. thanks
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
lik2waterski
Post by lik2waterski »
Thanks for the file. How are the lights attached?
johno down under
Post by johno down under »
Thank you for the file, it came in very handy when I removed the fruit tree and I was told that I would have to replace it with something! :D :D
Cheers Johno
DaveRad
Post by DaveRad »
lik2waterski wrote:Thanks for the file. How are the lights attached?
Hot Glue. Very late on the reply sorry
vanderburg1
Post by vanderburg1 »
How are you attaching the Rebar?
lucky7sg
Post by lucky7sg »
This will be a great file. Thanks
wilkinsdennis79
Post by wilkinsdennis79 »
where did you get the lights? The flowers look good
szextreme
Post by szextreme »
Am I missing something? pictures are all showing overlapped pedals but file doesnt look that way? Nice work though!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinery!
Ryan
Post by Ryan »
He said he uses a small roller. I assume that a sheet metal slip roll?
DaveRad
Post by DaveRad »
When you roll the leaves they will overlap each other. Yes I use a small slip roller for the leaves.
DaveRad
Post by DaveRad »
I get the LED lights from your local home improvement store or you can order online but I like the see what I am getting when buying them. A bit more expensive but you can get them for $1-$2 at depot or menards
DaveRad
Post by DaveRad »
Lights are hot glued to the painted finished flower. I weld the leaves to the rebar and paint them, then on the bask of the flower I weld a small piece of pipe about 1" long for the rebar to slide into, Makes it easy for winter storage since you can remove the flower from the stem.
4eleven
Post by 4eleven »
Thanks for sharing. I'll give these a try.
Post by djreiswig »
Is this they type of light you used? Do you just remove the stake and glue the top portion to the flower? It isn't apparent from the pictures if the center sticks up out of the flower.
DaveRad
Post by DaveRad »
Yes that will work. I use a larger domed light so I get more light effect. I just cut the part where the stake goes into off and hotglue the light to the flower. This is just a sample photo of the type I use.
