Gravel Truck - Dump Truck DXF
Hate to do this but have searched high and low for a good file of Kenworth, Peterbilt or equivalent gravel truck a little of front view mostly side view. Thanks in advance.Allan
Re: Need dxf of tandem or tri axle gravel truck
Check out google. Gravel truck clip art.
- drodgers
Traced in Inkscape havent cleaned it up.
Vicon Table
hypertherm hpr 130
Haco cnc brake
hypertherm hpr 130
Haco cnc brake
Thanks drogers that looks great.and thanks ironhorse for your reply. I've spent lots of time googling and its hard to come up with a realistic gravel truck dxf file.
This is one I saw on Google, maybe it will help. may need a bit of work.
Thanks all that gets me started in the right direction.
- david jordan
Re: Gravel Truck - Dump Truck DXF
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
