It is currently Wed Jul 18, 2018 4:06 pm
Rock grapple for compact tractor
schmaus
Postby schmaus » Sun Sep 10, 2017 9:09 pm
I drew this years ago. I cut one so I know it works. I used a diverter valve and cylinder from Surplus Center. there is a 50" wide model that is nested on a 4x4 sheet and a 60" model that takes a 4x8 sheet. I used 3/8" AR 400 plate. I would up it to 1/2" if you use standard hot rolled plate. assebly needs some round tube and square tube to finish.
Grapple.zip
Loyd
Re: Rock grapple for compact tractor
Postby Loyd » Sun Sep 10, 2017 9:22 pm
Thank you!
schmaus
Postby schmaus » Sun Sep 10, 2017 9:40 pm
Here are the hydraulic parts I used. the valve is mounted to the tractor to switch the bucket rotate to close the grapple when you press a button to energize the valve.
2x6x1.25 DA HYDRAULIC CYLINDER WOLVERINE WWXT2006-S part # 9-8771-6
12/24 Volt DC 13.2 GPM SAE 8 Solenoid Operated Double Selector Valve part # 9-8602
motoguy
Postby motoguy » Mon Sep 11, 2017 1:37 am
Very cool. Thanks!
exapprentice
Postby exapprentice » Mon Sep 11, 2017 7:33 am
Hi "schmaus"
Any chance you any pictures of these parts assembled to go with the file you posted ;)
just thought I would ask :?
Best Regards to all
Exapprentice :D
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting :(
schmaus
Postby schmaus » Mon Sep 11, 2017 8:49 am
I do have one picture but I have never resized a picture before so it may take a little while.
exapprentice
Postby exapprentice » Mon Sep 11, 2017 9:03 am
Hi schmaus
No problem, as I said "just thought I would ask" great if you could ;)
Best Regards to all
Exapprentice :D
(Pete)
tjenus
Postby tjenus » Mon Sep 11, 2017 9:05 am
Cool Thanks
5x10 Flow Waterjet
Postby Larry83301 » Mon Sep 11, 2017 11:27 am
schmaus wrote:I do have one picture but I have never resized a picture before so it may take a little while.
Here's an easy way to resize a picture, just load it into PAINT then click on the HOME tab and near the left side you will see the resize option. You can resize by percentage or by pixels, after you get it to the size you want click on FILE and do a SAVE AS so you will still have the original picture also. :D :D :D
schmaus
Postby schmaus » Mon Sep 11, 2017 2:09 pm
Thanks Larry! Easier then I thought.
schmaus
Postby schmaus » Mon Sep 11, 2017 2:12 pm
the mounts I made where for John Deere quick attach bucket. It could be easily adapted to skid steer quick attach. I don't have one to reference from.
Peechy
Postby Peechy » Wed Sep 13, 2017 4:55 pm
Great post ! Thank you
8-)
seajinx
Postby seajinx » Wed Sep 13, 2017 9:42 pm
Thank you very much for sharing.
Users browsing this forum: 43fabguy, elky_1965_02, firecapt, gamble, Google Adsense [Bot], samnwv, TTNicksocal, vic.pryor and 21 guests
