It is currently Wed Jan 17, 2018 1:59 am
Another Firepit
Econdron
Another Firepit
Postby Econdron » Wed Sep 06, 2017 6:04 pm
This isn't my design, I copied the design from someone else, but I did draw this up myself. I quoted it to a customer and figured I draw it up anyway even if they don't order it since I'll probably cut one for myself. I would love if someone could cut this before I do and tell me how it fits together! Designed to be cut from 1/4" thick steel, the slots are 0.27" to provide some clearance. Overall dimensions are around 30" W x 36" L x 12" H. The flat piece that sits in the frame is 8" W x 34.25" L. I think the square holes are for adding a gas setup. It's a neat design because it all slides in place and can easily be taken apart for storage. Here's some pictures of the 3D rendering I put together. You'll need to cut 2 of the sides, 2 of the walls and 1 bottom piece.
What I always do whenever I have pieces fitting together like this is draw up a couple small pieces with slots in them, then test fit the fit and adjust as necessary, just as a tip.
Firepit Wall.dxf
Firepit Side.dxf
Firepit Bottom.dxf
Gamelord
Re: Another Firepit
Postby Gamelord » Wed Sep 06, 2017 8:57 pm
Nice and clean, thanks for the share.
Torchmate CAD
jaywjnt
Re: Another Firepit
Postby jaywjnt » Wed Sep 06, 2017 9:59 pm
I will be trying this out...Thanks for the share
mayper
Re: Another Firepit
Postby mayper » Wed Sep 06, 2017 10:45 pm
Thanks for sharing, looks good
svc707
Re: Another Firepit
Postby svc707 » Thu Sep 07, 2017 12:17 am
=) I was planning on making the same thing started drawing it too off the sample images they had but never finished
hbg
Re: Another Firepit
Postby hbg » Thu Sep 07, 2017 9:57 am
Is this a break away pit?
Econdron
Re: Another Firepit
Postby Econdron » Thu Sep 07, 2017 1:01 pm
Here's the exploded view
hdfaster
Re: Another Firepit
Postby hdfaster » Fri Sep 08, 2017 10:19 am
Thanks.
Sharp
Re: Another Firepit
Postby Sharp » Fri Sep 08, 2017 12:49 pm
that's awesome! thanks
tnbndr
Re: Another Firepit
Postby tnbndr » Sat Sep 09, 2017 9:35 am
Just looking at the design, what keeps the bottom from tipping and sliding down? I think it needs tabs that fit into slots on the two long sides to prevent that. JMHO
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
K D Metalwerks
Re: Another Firepit
Postby K D Metalwerks » Fri Sep 15, 2017 9:03 pm
saw one of these at a flea market a few weeks ago. Thanks
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
suity13
Re: Another Firepit
Postby suity13 » Sat Sep 16, 2017 9:52 pm
WOW amazing file thanks for the share
Econdron
Re: Another Firepit
Postby Econdron » Mon Sep 18, 2017 5:46 pm
Has anyone else cut this yet? I just cut it out a couple days ago. I did a test fit and I thought the fit was too loose. I didn't adjust the drawing, I just slightly scaled down the file when loaded into SheetCAM. I think I did 1:24.5 instead of 1:25.4. I should have just kept it, the fit was too tight and once it did go together, it's a pain getting it apart. I just have it setup as a display in my showroom, so no big deal. As for the center piece falling down, it actually fits pretty nicely. I think the angles are steep enough to keep it centered pretty well. You have to push down pretty hard on one side to get it to slide off-center at all.
So I'm just curious if anyone cut the file as-is and if it went together smoothly or not?
Users browsing this forum: mdwalker, reklez2010 and 15 guests
