Self-centering vise
Code-man
Self-centering vise
Post by Code-man »
I have been searching for a dxf of a self-centering radial vise and I know I seen on here but for the life of me I can't find it. I could also be searching the wrong things. Any help would be great. Thanks Kody
WyoGreen
Re: Self-centering vise
Post by WyoGreen »
I think you are talking about a Longworth Chuck. I seem to remember a thread about that on here.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
motoguy
Post by motoguy »
Same thing as the mechanical iris?
Over the years I have used several different chucks that were the 4 jaw self-centering type. One even had a 4 direction adjustment so you could correct any out of trueness in the chuck. Most of them only scrolled in the 4 jaws just like a three jaw does. :D
Code-man
Post by Code-man »
The mechanical iris is what I was thinking. I'm thinking I could use that as a vise to hold a tube when I'm notching it. It should be able to keep the tubes on center line for cutting.
hemichargersrt8
Post by hemichargersrt8 »
Might as well throw my two cents and three pics into the discussion.
Code-man
Post by Code-man »
Hemi
That is a nice design. It looks really strong. What size of tubing will it hold and have you made one yet?
hemichargersrt8
Based upon baileigh model tn 250 tubing notcher. No I have not cut one, just decided to do a little research on your behalf. Tube size from 0.5" to 2.5". Should be relatively easy to plasma/laser cut and assemble.
Code-man
Post by Code-man »
That is the exactly the same one I have been looking at for a few days. Was on the fence about buying one or building a plasma notcher. Did you find that model on here?
hemichargersrt8
Nope, just started it tonight, still needs more work to complete.
Code-man
Post by Code-man »
That's great work. What are you designing it in? Solidworks? Would you be willing to share the dxfs?
hemichargersrt8
yes, solidworks and yes i will share when complete
Code-man
Post by Code-man »
Thank you.
Lowagon
Post by Lowagon »
following, great work so far.
KIDTech
Post by KIDTech »
Yes, that is slick! I made something similar a while back, it works but not as smooth as I intended. Would love to compare yours with mine someday.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
hemichargersrt8
work in progress....
szextreme
Post by szextreme »
Nice work! Can't wait to see this in action!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinery!
CHASSISWORX
Post by CHASSISWORX »
nice! following for sure!
hemichargersrt8
Finished concept model. I will try and cut a prototype over the next couple days before posting files.
steel 35
Post by steel 35 »
Oh and more art work! I am in also.
I want a hole to put bearing's in for a steady rest though. :lol:
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Serenityfab
Post by Serenityfab »
What would you use it for? Other than just to hold something? I have one on my pipe threader.
Serenity Metalworks
Bozeman, Montana
Plasmacam with homemade vent hood and Penn State dust collector
Hypertherm torch
It's not the size of your shop but what you do with the tools inside!
joesprocket
Post by joesprocket »
It would work great on a pipe/tube notcher
seajinx
Post by seajinx »
I have this one if anyone can use it
Longworth.zip
Lanemfg
Post by Lanemfg »
I would love the dxf when you are done, that looks awesome
