It is currently Mon May 21, 2018 1:00 pm
USN 2 layer 5 piece Commerative / Memorial with Candy Finish
rickjamesbish
Postby rickjamesbish » Sun Jun 18, 2017 7:04 pm
Completed this a while back using an anchor image from here as the base to start with. This is two layer, 5 piece, painted candy Gold and Blue and finished with 2k Clear. Held together by Super Magnets. This was presented at his retirement and went over quite well. Hopefully someone will be able to convert this to DXF in case anyone needs it. I ran into no issues in Design Edge but it seems that converting to DXF results in some anomalies.
USNMemorial.pcm
little blue choo
Re: USN 2 layer 5 piece Commerative / Memorial with Candy Finish
Postby little blue choo » Sun Jun 18, 2017 7:21 pm
Looks Great
Rick
Rick
Arclight 9600 4x8 table
Specialkfab
Postby Specialkfab » Sun Jun 18, 2017 7:39 pm
How do the magnets work. Do you orientate the pieces then apply the magnets on the back to hold together?
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
rickjamesbish
Postby rickjamesbish » Sun Jun 18, 2017 7:55 pm
They work great. I just throw them on strategically. Like on this one I placed them on back of the ring with lettering and the USN and then assemble. No glue or anything like that however I have used JB Weld on one side of some larger pieces so magnets stay in place on one piece. Hold piece and give it a bump to make sure it holds. Add more as needed. I use this on most all layered pieces so client can take apart for dusting, shipping , storage, etc. No complaints so far.
james.davis
Postby james.davis » Sun Jun 18, 2017 8:11 pm
Postby acourtjester » Sun Jun 18, 2017 10:10 pm
Nice work my daughter retired 2015 a chief.
I checked out the conversion to DXF and there are 2 lines for everything :cry:
Everlast PM 256 tig
bigworm36
Postby bigworm36 » Sun Jun 18, 2017 11:11 pm
Looks awesome I like the magnet idea, I have been welding on threaded studs, where do you get your magnets from?
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
rickjamesbish
Postby rickjamesbish » Sun Jun 18, 2017 11:49 pm
bigworm36 wrote:Looks awesome I like the magnet idea, I have been welding on threaded studs, where do you get your magnets from?
Amazon. Not that expensive considering the time it saves. I have not shopped around so likely can get better deal.
rickjamesbish
Postby rickjamesbish » Sun Jun 18, 2017 11:50 pm
acourtjester wrote:Nice work my daughter retired 2015 a chief.
Yeah someone else converted a flag I did and weird stuff happened. Maybe I should post it without the design edge cut paths.
Postby acourtjester » Mon Jun 19, 2017 9:42 am
I would like that it may make a difference with the double lines
Tom
Everlast PM 256 tig
rickjamesbish
Postby rickjamesbish » Mon Jun 19, 2017 9:59 am
acourtjester wrote:I would like that it may make a difference with the double lines
Tom
This is prior to converting to cut paths so it should show up as just single set of lines with no lead ins unless the software your using automatically converts it to a cut path.
USNCommerative.pcm
Postby acourtjester » Mon Jun 19, 2017 12:53 pm
Thanks but I use either DXF or SVG file formats maybe someone here can convert PCM to one of those :)
Everlast PM 256 tig
Specialkfab
Postby Specialkfab » Mon Jun 19, 2017 1:01 pm
Looks like James converted it to DXF with the cut lines for a Plasmacam applied.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
doublesix
Postby doublesix » Sun Jun 25, 2017 12:46 pm
That is beautiful I am going to have to look into magnets great idea.
JesseB
Postby JesseB » Tue Jun 27, 2017 10:52 am
Very nice. Would like to make one for my Dad. What is the font used?
rickjamesbish
Postby rickjamesbish » Tue Jun 27, 2017 11:30 am
JesseB wrote:Very nice. Would like to make one for my Dad. What is the font used?
Don't recall and will need to look when I get home. I had to break apart fonts as needed to prevent fall outs. It as not a ready cut font.
JesseB
Postby JesseB » Tue Jun 27, 2017 11:36 am
Thanks, Showed it to my Dad he really likes it. He's looking forward to getting one.
Users browsing this forum: chuck, covingtoncg, MosquitoCreekDesign, papawulf, Pengwynn, Specialkfab and 8 guests
