Aluminum dry box
Yellowstone
Aluminum dry box
Post by Yellowstone »
Heres a box or two. they work for me. Glad I can finally contribute something
dry box master.pcm
Sampson 510, TD cutmaster 101, Snap n Cut, 10' x 14g finger brake, lots of Welders tig,mig, aluminum push pull, vantage 300, sa250d, Ford Trucks.
Faulknerm
Re: Aluminum dry box
Post by Faulknerm »
I can't open a .pcm
plain ol Bill
Post by plain ol Bill »
Me either - don't you just hate those proprietary file extensions. Primary reason I don't have a Plasmacam. But then everyone knows I'm just a cranky ol guy.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
rdj357
Post by rdj357 »
I tried to post the dxf but it's 1.5 MB. There are stray parts and pieces so I'm not sure what goes where.
What are the joints on these? They look like rollformer edges so maybe not many would have that?
Yellowstone
Sorry I'll post more info.
Yellowstone
These are 14Lx8wx10D
Yellowstone
The corners are really all you need to make any size box you like just build the lid first. Then build the main box, then fine tune the sides.
Yellowstone
Oh and don't get the box wrapped around the break. Been there done that. Break the two main box lips at .5 then flip and break the opposite way on both sides then do the side, bottom and side. 22 bends total in this box style. Makes for a strong lid. You can do up to a 32" box on a Chinese 4' brake with .080 AL. Need bigger tools after that.
Yellowstone
Here's a gun case as well. Same deal. Just cut the corners out, snap to grid and apply to your specific box size. The lid will grow about a quarter inch both directions so if you want 32" x 12" go 31 3/4x 11 3/4 on the lid.
TimP
Post by TimP »
Those are awesome! Thank you for sharing, but for us folk who use DXF files, is there a chance we can get a conversion?
Thank you!
Tim
Yellowstone
I'm not that up to speed on file format changes. Hopefully someone who is more savvy than myself can help.
rdj357
Post by rdj357 »
Yellowstone wrote:I'm not that up to speed on file format changes. Hopefully someone who is more savvy than myself can help.
If you have advanced Design Edge you pick save as, then choose dxf. Remember file upload max here is 1mb. You may need to break it apart in a few files.
Yellowstone
I'll give it a shot.
diyweldingplans
Post by diyweldingplans »
I tried with Corel Draw and Enroute, no luck. They don't recognize PCM.
Faulknerm
Post by Faulknerm »
I need a new brake sooooo badly!
Jealous of your work!
Yellowstone
No dice, don't get an option to save as dxf, pcm only. I'll add a smaller file with just the small box and maybe someone can help.
Yellowstone
Heres the box in the photo, should be a muc.h smaller file
8x14x11 box.pcm
rdj357
Post by rdj357 »
Here's that one in DXF. It was cut paths in PlasmaCam so I trimmed off the lead-ins and joined up the paths before saving as a DXF.
Lots of folks here need regular closed and open paths so they can process them in their machines or SheetCam. So if you do have Advanced Design it is always easier to choose Export under the file menu and then save your drawing as a DXF so that everyone can use it. Those of us with DesignEdge/PlasmaCam can easily import the DXF.
8x14x11 box.dxf
Yellowstone
Thanks Robert,I'll try the export next time. I'm pretty new to the computer gig. Shortcuts are helping.
When you lay out the main box it's 10 7/16" from the end (the ends where you will bend the lip) to the bend that will be the bottom of the box. |_|
I always do the lid first. And don't over bend the second bend on the lip on the main box.
This size box will break easily on a 4' brake in .080.
