Convincing Curved Rope
rickjamesbish
Post by rickjamesbish »
Been trying for hours to make a segment or curved rope but cannot seem to pull it off. Any help appreciated. Just need an S shaped segment of rope to use as accents under text. Seems like it would be simple but I just cannot make one that looks convincing.
RobinHillMachine
Re: Convincing Curved Rope
Post by RobinHillMachine »
How big are you cutting it and is it positive or reverse cut?
The issue you are most likely facing is a rope is twisted of many fibers of course. And to give a real rope look to a file, you have to add a lot of detail depicting all the fibers twisting and looping each other.
Let me know about the size and type of cut you're looking for. I may be able to help you.
Julie's the name, DXF is the game. http://robinhillmachine.com
Email DXF@robinhillmachine.com
rickjamesbish
Well the rope will be cut into a piece of steal so I guess that would be a negative. So the edges and the line that represents the twist would be cut out. I ended up making something that will work but now I want try and make a rope with two loops and loose end hanging.
rickjamesbish
This is what I ended up with.
RobinHillMachine
Looks good.
Old Iron
Post by Old Iron »
:D Nothing wrong with that
rickjamesbish
Maybe.... I have not cut it yet. It might be to tight. Will see tomorrow.
little blue choo
Post by little blue choo »
You don't need help with that. It looks great. I think you nailed it.
Rick
Rick
Arclight 9600 4x8 table
