Fidget Spinners??
Fidget Spinners??
Hello guys. New to site . Love all you guys do. My 8 year old son wants to make some fidget spinners. Does anyone have a DXF files or can someone make a couple. Thanks in advance. Thanks Craig
Re: Fidget Spinners??
whats a fidget spinner?
These are handheld toys kids are playing with. They have small skateboard bearings in them. They hold in hand and spin.
These seem popular, I don't get it, but....
They seem to use 22 mm bearings, but I would use whatever size you can find cheap, resize the holes to match the bearing outside diameter and epoxy the bearings in place. Use material thickness to match bearing thickness.
WOW. Thanks so much. My son will be so Happy. Hemi I sent you a message.
thanks
My son brought one of those home last week. I played with it a while, too. Didn't know they were called "fidget spinners". The designs above look neat...thanks! I think these would be better suited to a 3d printer, though, vs plasma. My son's plastic one can spin mighty fast...I hate to think what it could do to a digit, if it's made of 3/16" material...
- Capstone
These "fidget spinners" are a phenomenon sorta like the hackey-sacks when I was a kid. The basic idea is that there are a bunch of people who have OCD/ADD tendencies and this "fidgeting" helps calm a portion of their brain to enable better concentration on the task at hand. What has grown from it is an ever increasing amount of precision and speed through the use of ceramic space-age bearings and highly precise milling of rare metals. I actually met a couple of guys that produced a fidget that costs $700 each, and they are pre-sold out already of over 200 of them, so obviously there's a market. I agree that plasma-cut metal will not unfortunately be part of this craze. 3D printing, which I also do, will, but even that has limitations. It's the people with milling machines that will ultimately reap the most profit.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- rdj357
Many thanks for sharing the files! I have a laser coming that I plan to customize and cut these from acrylic to sell!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
ok i have been trying to find acrylic... any suggestions on the best place to get it?
- rdj357
Check out Laserbits.com and Inventables.com
I don't have my laser here yet but i have both of those bookmarked as they have been recommended on several forums.
Robert Johnson
- Larry83301
I have used Tap Plastics several times, worked out OK.STEEL3470 wrote:ok i have been trying to find acrylic... any suggestions on the best place to get it?
https://www.tapplastics.com/
thanks, work good with acrlic and co2 laser
I cut 3 out of 3/16 Steel. Worked great. Waiting on bearings now.
Post some picks once you get the bearings I would like to see how they turned out. I assume you have to drill out the bearing holes so they are more precise?
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
bearings is the biggest issue allot of suppliers are running out, im 3 weeks out on my bulk order of bearings,
i cut a few fidgets out of acrylic yesterday and they turned out great just going to press the bearings in and done. im using a laser though.
file turned out great thanks
here is the pic
Nice to see people post pics. I always wonder if people only download the files that people take the time to create.
Looks great. Here are mine. Waiting for bearings now. Thanks Hemi.
Here we go
Spin away Vanquish!
Thanks hemichargetsrt8, grandson was wanting one of these. great files.
I'm having problems with bearing. I first drill a 22mm then we t to 55/64. 22mm to big 55/64 to tight. What are you guys doing. I'm using 3/16 metal. Might have to use a different material. Thanks guys.
Heat the bodies, freeze the bearings? If it's only a few thou seems like they should slide in. Much more than that might make the bearings bind.
