Could someone please convert to a dxf file. For some reason I can not import from my scanner to Plasmacam. Thank you
Cartoon Bee Conversion
- RobinHillMachine
Re: converting to dxf
Your photo is too small.
ok Ill see if I can enlarge it
- Francisco
Directly enlarging the image you posted will probably not improve things. Said image seems to be a scan of the complete scanner's bed; try scanning just the area of the drawing, and increase the scan resolution to maybe 600x600 or 1200 x 1200.
If you do a search on google for bee clip art or cartoon bee's you may fine the bee the lettering is easy after that to create your own file.
https://www.google.com/#q=cartoon+bee+clipart
- lockeyone
I was bored in my office today, too much rain and most of my work is outside.
This is my attempt. I just mirrored the hand. I won't do the fonts and would just do a search for something close. Probably could use some tweaking to be cut-able. Done in my Vectric Aspire.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
- RobinHillMachine
DXF and SVG in the folder. One is attached and will cut in one piece, the other will have the mouth and eyebrow cut separate. Backing plate included.
Please post a picture of the finished product.
Re: Cartoon Bee Conversion
This is awesome thanks! Can't believe the OP didn't reply...hopefully he just never checked back. Thanks again!!
This is really cute. I have made it showing the design on both sides. Beware! That stinger is VERY sharp. I would post a photo, but do not know how. Am new here.
- Larry83301
If you don't have a way to save a picture of our file just do a print screen and then open PAINT and paste from the clipboard. If you have WIN 10 you can use the Snipping Tool to save a JPG of whatever is on your screen.patrog wrote:This is really cute. I have made it showing the design on both sides. Beware! That stinger is VERY sharp. I would post a photo, but do not know how. Am new here.
