Frog and turtle crossing.
I have not cut these yet. Drew them up last night for a customer order. Figured I would share since I get so much from this forum!
Re: Frog and turtle crossing.
Can anyone repost these in DXF? Thanks for the share VPT!!!
Cute!! Thank you VPT
Cut out 4 of each yesterday. They cut good for me. I welded some rod to each one so they can be stuck in the ground. I used the boarder from another sign I downloaded and it does appear rough. The edges do come out smooth when cut but I still may go back and fix this some time as it is easy enough to do.
Here is a screen shot of both together opened in plasmacam.
- hdfaster
Thanks for sharing.
Thank you, cute files. Is there anyone who could put them into a dxf? If I could I would be happy to, but I can't, at least not yet! What program do you use to do that. I work with TMs cad.
Nice file thanks for the share
Homemade 5x10 watertable
Hypertherm Powermax 65 w/ Ohmic and machine torch and Proma THC
Solidworks, Inkscape, Draftsight Sheetcam, Mach 3
Files in DXF...........Russ K
Thank you for the dxf files, Russ. What program do you use to change it to dxf?
My Design Edge Program (PlasmaCam) uses the proprietary PCM format but will import or export in either DXF or PCM..............Russ K
Does that work in 3.11 as well? I always just save the files in default format.
Design Edge will import the older pcm files , import or export the newer pcm's or dxf. RK
