Community College Logo to dxf
Hi, looking for a trace of our college's logo. Once it's in dxf I can tweek in AutoCAD. Thx for any help in advance. Very helpful community here.
- Gamelord
- 4.5 Star Member
Re: Community College Logo to dxf
Do you have a higher quality image or even a larger one? Tracing an image this small gives poor results. If you know what the font(s) are then it would be easy to make as well.
Torchmate CAD
Torchmate CAD
This is a bit bigger, unfortunately, no I don't know the font. I've talked to our IT department to see if we own Corel Draw and we don't. I've also attempted tracing manually in AutoCAD getting not great results. The "college works" part could be left out, I'm sure I could find a similar font. Again, thanks for help eh.
Here's a start. You should be able to import an .svg into acad. Sorry I haven't found a program that will reliably convert an svg to a dwg or dxf or I would have given you that. It still needs a little work.
Nasty little file there. lol
Hrm, no luck opening it in AutoCAD... any other takers able to convert this to dxf or dwg?
- lockeyone
Try this, import ovrrdrive's file into CorelDraw X6, outlined it, exported as pdf. Opened in Aspire and exported as DXF. See it it works.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
Not cut ready and you will need to scale to desired size.
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
Beauty! thanks so much from NB, Canada
