font share thread
mrbuildit
font share thread
Post by mrbuildit »
here's a couple fonts I use quite a bit. hopefully someone finds them useful. feel free to post up other saved fonts.
mt condensed bold.dxf
stencil bold.dxf
Rem300wm
Re: font share thread
Post by Rem300wm »
Hello to All
Thank You for sharing the fonts.
Rem.
Dingo745
Post by Dingo745 »
Thanks mate :)
Maadman
Post by Maadman »
Always looking for good fonts. Thank you for sharing.
Thanks for sharing
jason.jason.p
Post by jason.jason.p »
I use a program many of you are probably already familiar with called DeskEngrave. It's free and easy to use, it uses fonts already installed on your computer and exports them in dxf or gcode. I do all my drawing in CAD so not sure how or if this will work with the folks primarily using SVGs. Additional fonts are easily downloaded and installed from dafont.com . Thais program makes it really easy for me to put words on a radius and quickly switch between different fonts with a preview window so I can pick which font looks better for a project.
http://www.deskam.com/deskengrave.html
There is also a program called stickfont which I've used on rare occasion to make open line fonts.
Motoxrdr
Post by Motoxrdr »
That DeskEngrave is awesome! thanks for the link, what a time saver.
Metal teacher
Post by Metal teacher »
thanks
BAR M
Post by BAR M »
Thank you.
taberahkj
Post by taberahkj »
Here's a couple I got from the Solid Works forum that's designed to be ready to cut for laser.
TC_LaserSans.TTF.zip
TC_LaserScript.TTF.zip
Beevo
Post by Beevo »
THANKS
