Hello
I would like to draw block letters and cut them with my plazma table can any one help me ?
Little Bit
cutting letters with plasma table
Re: cutting letters with plasma table
dafont.com.....1001fonts.com...... lots of free fonts and im sure there are block fonts available there
- Larry83301
There is a font in windows called block, it looks like this - -
If it's not in your version of windows just PM me and I'll do the whole font set as a DXF for you.
There is even software that will create a stencil font from any font and Inkscape will create the font in whatever size you need make the "object a path" then save as SVG or DXF... Sheetcam will allow you to create letters from the fonts available... there is Arial which is essentially a BLOCK font.
I can create a ttf font for you with cut letters. Please pm me with the font file or email me at kelly @ diyweldingplans.com. I do charge $50 per font but once you have it you never have to edit again.
hopefully this helps you out. this is what I use for block type letters.
thank you very much
