I have not cut this yet. I may need to remove some detail in the small plants depending on the size of piece when its cut.
Until I hit the jackpot Im stuck with the basic version of Design Edge so I cannot export DXF. This is PCM but Im sure someone on here will be kind enough to download, open in Design Edge then export and respond with DXF.
You will see two pieces. One with lead in lines, which is the piece converted to cut paths. The other has no lead in lines. I included both because if you need to edit I find it easier to do so before cut paths are added... at least it is for me in Design Edge.
Coyote Desert Moon Howl
Re: Coyote Desert Moon Howl
I also have this with round border and will post later
I really like this art. I have pcm but it won't download. Do you know why? Thanks in advance!!
Hmm.. wont download from this site or won't open in Design Edge ?metalarts wrote:I really like this art. I have pcm but it won't download. Do you know why? Thanks in advance!!
Re: Round Boarder
Here is the round border version. This has not been converted to cut paths. Again only PCM. Would someone be kind enough to convert to DXF or point me in the direction of software that will do it ? Thanks
Won't download from this site. would love to convert to DXF but cannot download either one.
- see&see
Converted to DXF.....
You marry into the PlasmaCam family and must accept the fact your software and hardware are proprietary. It's a for better or for worse engagement with overwhelming security. PlasmaCam controls the computer, table, hardware to their advantage IMO.
thanks very nice
Looks good thanks.
