American Flag with Full Pledge
- edclayton1
Re: American Flag with Full Pledge
Thanks this really nice.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
- little blue choo
Metal Dyes and Automotive clear.
Rick
Rick
Rick
Arclight 9600 4x8 table
Beautiful work!
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
This is an automotive grade candy paint I used with 2k Clear Coat.Cheeseburger760 wrote:what do you guys use for paint or is that powder coat?
I love the font, Do you know where you found it and what it is called
Thank You!!
- 9er
Sorry to resurrect.
I downlaoded the DXF, opened it in inkscape to try and size it up. I want to cut this out of a 5x10 sheet for our shop. Probably overall size in the range of 58" x 118" ish. Each time I make the mod, re-save it, then open it on solid edge, it's back to regular size. ANy idea what I'm doing wrong?
Arclight Arc Pro 12000
Hypertherm PM85
Hypertherm PM85
I love it Can I get it in a dxf file thanks
- 9er
The DXF file was in this thread. I was just hitting a snag trying to re-size it and looking for help.
Hypertherm PM85
Hypertherm PM85
Not sure what would cause that but try saving the modded file under a completely different name so you know for certain you are opening the modded file. Sounds dumb I know but I have made that mistake in the past9er wrote: ↑Sat Mar 21, 2020 6:08 pm Sorry to resurrect.
I have attached a 58" tall dxf 9big file so I zipped it) to this in case you can't get it figured out
That file is awesome. Thank you for sharing. How do you download the .SVG file? When I click on it it brings it up in an explore window?
Looks like your PC is set up to open .svg files with your web browser.holdensbizz wrote: ↑Thu Mar 26, 2020 9:01 pm That file is awesome. Thank you for sharing. How do you download the .SVG file? When I click on it it brings it up in an explore window?
Try right clicking on the file and from the drop down menu click on "Save link as..." and then you will be able to choose where you want to download it to on your PC.
Thank you that worked. I was able to down load it and open it in Inkscape. Forgive me Im still new at art and plasma. Should there be that many nodes for the Lettering?sonbakler wrote: ↑Fri Mar 27, 2020 10:35 amLooks like your PC is set up to open .svg files with your web browser.holdensbizz wrote: ↑Thu Mar 26, 2020 9:01 pm That file is awesome. Thank you for sharing. How do you download the .SVG file? When I click on it it brings it up in an explore window?
Does someone know the name of this type font?
I'm interested in this font as well. Thanks.
Thanks for the file and all who helped along the way.
Awesome work!! Thanks for the share.
