Someone came to me with this saying and asked for a sign with a coffee cup and the saying in it. Hope someone can use this...
it is designed to cut approximately 2' x 2' so you may want to scale up and down to your preference. Also I didn't cut it out or spend enough time looking it over so you may want to make sure that there are no dropouts or lines too close together for your system.
Perfect blend
Perfect blend
5x10 Dynatorch High Definition plasma table. Cuttingshop drawing program. Sigmanest nesting program. Custom fabrication and powder coating.
Whatsoever thy hand findeth to do, do it with thy might Ecclesiastes 9:10
- little blue choo
Re: Perfect blend
lklassen331 Check your drawing. It appears you're going to spill your coffee. LOL
Rick
Rick
Rick
Arclight 9600 4x8 table
Re: Perfect blend
Sure enough I meant to add gaps in there and plumb forgot! Have to do that in the morning... Thanks for pointing that outlittle blue choo wrote:lklassen331 Check your drawing. It appears you're going to spill your coffee. LOL
Rick
- little blue choo
Re: Perfect blend
I just hate to see good coffee go to waist. On my second cup now.lklassen331 wrote:Sure enough I meant to add gaps in there and plumb forgot! Have to do that in the morning... Thanks for pointing that outlittle blue choo wrote:lklassen331 Check your drawing. It appears you're going to spill your coffee. LOL
Rick
Rick
Rick
Re: Perfect blend
Looks good to me. I am not seeing where more gaps are needed. I need to get new glasses. What am I missing?
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
- little blue choo
Re: Perfect blend
K D He corrected the file. It is good to go now, so pour a cup and cut a cup. LOL
Rick
Rick
Rick
Re: Perfect blend
thanks
Re: Perfect blend
cute thank you
