It is currently Fri Jan 19, 2018 4:01 am
large self closing hooks
Sawdustcreek
Postby Sawdustcreek » Sat Jan 07, 2017 2:14 pm
Am looking for hooks of a self closing style, or drag to close for a log arch project. Rather than reinvent the wheel, if any body has a design they would like to share, it would be much appreciated..don
primaldesigns
Re: large self closing hooks
Postby primaldesigns » Sat Jan 07, 2017 9:21 pm
Try searching for Gravity Hook
Sawdustcreek
Postby Sawdustcreek » Sun Jan 08, 2017 12:26 pm
did, not big enough..trying to move 24 inch logs
mdwalker
Postby mdwalker » Mon Jan 09, 2017 5:59 am
If the principle works all you have to do is scale them up to what size you need.
lockeyone
Postby lockeyone » Mon Jan 09, 2017 9:12 am
I think he is looking for something like this. Should be easy enough to draw one up.
Epilog Mini 24 60watt, 2013
Sawdustcreek
Postby Sawdustcreek » Mon Jan 09, 2017 2:22 pm
pretty close...there is a guy on youtube called the unemployed redneck...his log arch is a work of welding art...he made his own log pullers...i'm just being lazy...
mdwalker
Postby mdwalker » Mon Jan 09, 2017 7:29 pm
How lazy are you? I will make a set and sell them to you, lol
Sawdustcreek
Postby Sawdustcreek » Tue Jan 10, 2017 7:01 am
not that lazy
OakRidgeFarms
Postby OakRidgeFarms » Tue Jan 10, 2017 6:16 pm
Just chiming in with my thoughts on this. I haul a lot of logs (dragging them through brush, rocks, stump holes, etc...) My suggestion to you is to buy a set, and do not try to cut them out of regular steel. Most manufacturers of these choose cast or hardened hooks for a reason. Unless you are planning to cut them from one inch plate or thicker, they will just bend, twist and not be very effective. I would consider a sling chain or cable for larger logs. Hooks work great, don't get me wrong..... But a sling chain on a 3 point lift works great too. Not as quick as dropping a hook on them for sure, but easy to sling one if you use a cant hook. I wish you luck if you do decide to make one, please let us know how it works, I love to be corrected.... :)
Tracker CNC Nitro 4x8 Table
Powermax 85
SigmaNest
Corel Draw x7
Hobart Handler Wire Feed
Miller Bobcat 250 Welder Generator
http://www.facebook.com/ORFarms
Bobcat320
Postby Bobcat320 » Wed Jan 11, 2017 4:11 pm
OakRidgeFarms wrote:Just chiming in with my thoughts on this. I haul a lot of logs (dragging them through brush, rocks, stump holes, etc...) My suggestion to you is to buy a set, and do not try to cut them out of regular steel. Most manufacturers of these choose cast or hardened hooks for a reason. Unless you are planning to cut them from one inch plate or thicker, they will just bend, twist and not be very effective. I would consider a sling chain or cable for larger logs. Hooks work great, don't get me wrong..... But a sling chain on a 3 point lift works great too. Not as quick as dropping a hook on them for sure, but easy to sling one if you use a cant hook. I wish you luck if you do decide to make one, please let us know how it works, I love to be corrected.... :)
Agree with you 100%. I have made several sets, but have used either 3/4" or 1" round stock, forged to shape and then tempered. I would not use one cut out of flat stock... unless it was just small logs or such.
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
abmetal
Postby abmetal » Wed Jan 11, 2017 7:35 pm
What if a person were to cut some from AR500? Just curious.
Allen
OakRidgeFarms
Postby OakRidgeFarms » Thu Jan 12, 2017 7:20 am
I have never dealt wit AR500 myself, so I can't really say one way or the other. But I know it is pricey, so is it worth trying? Have to ask yourself on that one. I think I would still go with mine or Bobcat320's thoughts. Better safe than sorry.... Would hate for you to make the investment, both time and money, only to have it fail. Hou have to ask yourself one question though... If they could be made with a plasma cutter (and be effective), why has nobody else done it. It would be a far quicker fabrication process (and cheaper) than forging them, or casting them.... again, just food for thought.
However, with that said... It might be your flugelbinder, and make millions... never know until you try LOL
Powermax 85
SigmaNest
Corel Draw x7
abmetal
Postby abmetal » Thu Jan 12, 2017 8:31 am
I have no intentions of making any but just curious. There's a local fab shop that builds guard towers and they have a considerable amount of AR500 scrap left over so I'd think that'd be pretty reasonable. In the past I've bought AR400 from them at a good price.
Allen
SONIC
Postby SONIC » Thu Jan 12, 2017 9:15 am
If it were me I'd just cut 2 sets out of 1/2 or 5'8 and then weld them together for a full inch of 1 1/4.
Maybe even weld a spacer in between to give a little more torsional stability.
lockeyone
Postby lockeyone » Thu Jan 12, 2017 12:19 pm
I was thinking similar this morning only I was thinking either cut one finger heavy metal, other side two fingers lighter with welding or staggering the other fingers. If I were to do something like this I have a tendency to overbuild. But it sure helps with the stories/suggestions from experienced members. Kinda like image.
Bobcat320
Postby Bobcat320 » Thu Jan 12, 2017 12:36 pm
SONIC wrote:If it were me I'd just cut 2 sets out of 1/2 or 5'8 and then weld them together for a full inch of 1 1/4.
I had not considered doing it this way (been forging long before I had plasma cutter), but I think it would work if done right!
PlasmaCam DHC2
Hyperthem PM65
Users browsing this forum: Bing [Bot] and 4 guests
