Jeep Hardtop Mountain Scene
Folks,
Here is a Jeep file with mountain scene I just finished up....about 36" wide. Dropouts are shaded white in the photo below. I have not had a chance to cut it yet, and you will for sure want to check it....lots of tight lines and open cuts. I tried to get rid of most splines, but there are still a few in the tire treads and hoping they cut okay. As an option, I have a layer (its turned off) called "treads" which is a simplified version of the tire treads, but had only done it for the passenger side front....to lazy to finish the others . Anyhow, let me know it cuts good, and feel free to post back any modified versions.
Thanks.
Thanks.
Hypertherm Powermax 65
4'x 8' Eagle Plasma Table
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Everlast 256S Combo Arc/TIG/Plasma
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
Re: Jeep Hardtop Mountain Scene
Could you post the DXF for us
OH man....I knew I was forgetting to do something....dang it! I will have to do it when I get back to my work station.....sorry folks.
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
I love jeep stuff, I this could be something nice for a jeep garage after some clean up
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Well, finally back to my shop. Here is the Jeep scene in dxf format, sorry forgot the most important file when originally uploading this post. Anyhow, hope someone can make use of it. As mentioned in the beginning of the post I have not cut this yet, and am somewhat concerned about all the single cuts for added detail....it may be a bit too much. Repost any better versions or photos of cuts you might of made. Thanks for looking!
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
- East German
Regards Peter
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- Nacs Fab
Thank you!
G540 with LCTHC by candcnc
all built... by me...
Awesome
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
nice job!!
That is awesome! Nice work!
- Larry83301
Very nice Jeep, thanks for the file!
Wow great work thank you
I spent some additional time on this to clean up the file as it had too many zero offset cut lines that were originally on there for detail. scaled up to cut 47" wide to hang in my shop. Started cutting it this weekend and my table bombed out so will have to try again after later. One could clean up further if you didn't want all the detail. Attached is the revised file.
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
Very creative, nice work thanks for sharing
Nice!!!!
Although I'm an FJ Cruiser guy, nice file.
TD Cut Master 52
TD Automation kit
Sl100 Machine Torch
ESAB Rebel 215 EMP
DD 4'x4' Freedom Series Table ( In Progress )
Inkscape, Sheetcam, UGS / Grbl
TD Automation kit
Sl100 Machine Torch
ESAB Rebel 215 EMP
- ben de lappe
Hmmmm...Vaguely familiar somehow....Oh yeah, I remember www.plasmaspider.com/viewtopic.php?f=6& ... eep#p44392
"Folks,
Here is a Jeep file with mountain scene I just finished up....about 36" wide. Dropouts are shaded white in the photo below. I have not had a chance to cut it yet, and you will for sure want to check it...."
Congratulations on all of your hard work. Matter of fact I did check it. Back in 2012. Scaled to 48" it comes out like this. Compliments of my friend Bobby.
Not seeking attention in any way here, but seriously...a whole thread and no mention where the centerpiece of your file came from?
"Folks,
- Scratch
Oooohhhhhh snap!
c'mon Ben.... the mountains were the hard part... and the punishers.... you can't just find that stuff online on a forum where files are shared, thats takes talent...uhhh...nevermind
- david jordan
Very nice, thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
- ben de lappe
Apparently being forthright is the hard part. Sure, I've found a neat file or two here that I have taken, modified a bit and re-posted. But when I did I was sure to give a tip of the hat to the person that devoted their time, thoughts, and ideas to the file I had taken to modify. Just seems like common decency to me.
Agreed, that makes sense and should be the expected norm
Gents....you are obviously Right! I should of given Ben a shout-out for his original posting. Typically I would just post a remake back under the original post and make mention, but failed to do it in this case for whatever reason. My apologies to all!
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
