20 Can spray bomb wall mount
Re: 20 Can spray bomb wall mount
Now I may get organized. Thanks for the two shares
very nice upgrade , just cut my first . Will definitely be doing the 2 break one .
Thanks to Allan101 and Old Iron for the file.
Walt
Walt
Now this is going to come in handy! Thanks Gents.
Hypertherm Powermax 65
4'x 8' Eagle Plasma Table
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Everlast 256S Combo Arc/TIG/Plasma
Millermatic 211
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
what a great idea. its the small things like this that some of us don't think about that really help.
- rons
Very nice but what we all need is a automatic can shaker
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Harbor Freight shaker works great!
Allen
Allen
fantastic idea sir, thanks for sharing...been looking for a good idea for bombs 6 months now..finally one that makes sense..thumbs up
looks awsome thanks
I cut the 20 can holder after I modified the file slightly. I wanted to hang it on the inside of my shop side door, and the leftover sheet of 14 Ga was only big enough for 34". So I scaled it in Inkscape all combined and this reduced the can opening down to 2-13/16" when cut with no offset. When I cut it the center line group cut from start to end and back to start without lifting the torch so I corrected ths in this attached file.
The expanded paint can holder wasn't quite 16" on center, so I moved the outside mounting holes in. This should be 16" on center now.
I wasn't quite sure what you meant, but now I see - you moved the holes for mounting to wall studs that are located 16" OC.
acourtjester wrote: ↑Wed Oct 17, 2018 4:45 pm I cut the 20 can holder after I modified the file slightly. I wanted to hang it on the inside of my shop side door, and the leftover sheet of 14 Ga was only big enough for 34". So I scaled it in Inkscape all combined and this reduced the can opening down to 2-13/16" when cut with no offset. When I cut it the center line group cut from start to end and back to start without lifting the torch so I corrected ths in this attached file.
20CanHolder.svg
Unfortunately for me, I would need very many of these to hold all my spray cans - and then of course wall space to mount them. But a great looking holder and I really like the color.
- Double S Farms
Very nice - thanks for the fine file!
