20 Can spray bomb wall mount
allan101
Post by allan101 »
For spray bomb, mounting is 16 inch on center
PaintCan holder2.dxf
Mcclure3
Re: 20 Can spray bomb wall mount
Post by Mcclure3 »
Thanks for posting.
sbest1
Post by sbest1 »
That will come in handy. Thank you
marvelmetalworks
Post by marvelmetalworks »
Thanks for the share !!!
Leon
Plasmacam 4x4
DesignEdge Advanced design software
Advanced height control
Hypertherm 45 xp
Thermal Dynamics Cutmaster42
Miller millermatic 130xp mig
Thermal arc 200 amp tig
steel 35
Post by steel 35 »
IT wont fit in my little HF press brake but I am thinking about it and Hope I can :mrgreen: Thanks
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Old Iron
Post by Old Iron »
allan, Thanks for sharing your file.
I took the liberty of modifying your drawing so it can be bent by hand by putting relief cuts in.
Paint Can holder 20.dxf
Jeffscott
Post by Jeffscott »
thanks this is neet
allan101
Post by allan101 »
Thanks Old Iron I never thought about that
HaasMetalDesigns
Post by HaasMetalDesigns »
I will be making one today for the work truck
JHART02
Post by JHART02 »
Thank you very nice!
johnp
Post by johnp »
Much thanks to the original poster! I cut three of these today (16ga steel), with zero modification to the original file. Very happy with the improvement to my shop!
Texas Metal Works
My Toys:
Vanquish
Post by Vanquish »
Very cool.
09 800r x
Post by 09 800r x »
Very nice, thanks. I’ll be making few of these
tylerd
Post by tylerd »
Has anyone tried to cut the file by Old Iron with the relief cuts added? When I set the operation in sheetcam I get the following......!Outside Offset Layer, Open Paths were not offset. The file I am talking about is....... Paint Can holder 20.dxf
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
krymis
Post by krymis »
i did in designedge and it cut fine.
little blue choo
Post by little blue choo »
No problem, Cut it. No offset for straight lines. It will cut the lines where they are drawn.
Rick
Rick
Arclight 9600 4x8 table
Searchman
Post by Searchman »
Thanks for the great share
tylerd
Post by tylerd »
Awesome, thanks for the reply!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Rex
Post by Rex »
Cutout Great
Hypertherm 65
RPM
Post by RPM »
Thanks guys that will come in very handy.
Jeepn2
Post by Jeepn2 »
Thanks, cut out of aluminum and turned out nice .
Precision Plasma Patriot 4X8, water table, Price THC, UC 400ETH, Floating head
Hypertherm 45XP - Machine torch
UCCNC, Sheetcam, Inkscape/Corel X5
Paint Chip
Post by Paint Chip »
The 20 can holder is a great idea and thanks to the OP for the share. Hope he doesn't mind, but I modified the drawing a little - I stretched it a bit and added 2 more folds - which allows the top row to stand proud of the front row so you can see the paint can colors in the back row (for us vertically challenged folks ;) )- see the pic.
20CanHolder.dxf
20CanHolder.svg
PPLLC 4X8 table w 620 ox steppers on 5 axes
Bladerunner CandCNC w/DTHC II
Hypertherm PM85
dholt87
Post by dholt87 »
Thanks for the files
edclayton1
Post by edclayton1 »
Thank you, this will come in very handy. Great idea.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
ggeh
Post by ggeh »
Thanks for both files, I cut two of them for my garage so far, excellent organizer thanks for sharing.
