Fun Project..... "3D Puzzle"
One of many I have... I love this one since I am a Marine... Kind of fitting...
Enjoy!!!!
Enjoy!!!!
Re: Fun Project..... "3D Puzzle"
What gauge of metal did you use
THANKS for sharing
REX
THANKS for sharing
REX
Hypertherm 65
Hypertherm 65
- steel 35
Great, Thanks.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Thanks very much! looks good...
5x10 Dynatorch High Definition plasma table. Cuttingshop drawing program. Sigmanest nesting program. Custom fabrication and powder coating.
Whatsoever thy hand findeth to do, do it with thy might Ecclesiastes 9:10
Thanks for sharing this.
thought about the gauge question... I made this mistake in the past... The best way to determine the best gauge for the project is dependent on how you size the overall piece. whether you down size or enlarge, always take a measurement of the gaps in the pieces. if you enlarge, thicker material will be required and the opposite if reduced.
How to you handle the small pieces when polishing/grinding?
On a laser there isn't any need to grind as long as the laser is set up properly and the slats on the table are clean. With regards to polishing small pars, If it is an Item I want polished, I use polished stainless to start. However, if I need to polish very small parts, when setting up the file to be cut I will add micro joints on the pieces so they stay in the skeleton. That makes it very easy to polish them. Then remove each piece. hope that helps...CCR Custom Metals wrote:How to you handle the small pieces when polishing/grinding?
- Capstone
very nice... thanks
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Wow, wish I could afford a laser cutter. I only have a cnc plasma.
that is cool thx for the post
Great work! Thanks. I've been looking for one of these. Curious as to what else you have....
Great file, thank you for sharing.
Great File sir, Thank you for sharing Merry Christmas to all!
DHC2 Plasmacam Custom 7’ x 18’ Plasma Table, Hypertherm 85 Plasma Machine Torch, Miller 875 Plasma Torch, Lincoln Aspect 375 TIG, Lincoln 275 TIG, Miller 200, Lincoln 250 SMAW, Lincoln 256 MiG Spool Gun, Miller 211, Miller 210 MIG, Miller Trailblazer 302
what was the overall dimensions of this when it was completed
