Heritage Classic
- John Frantum
Heritage Classic
2 customers were persistent that they wanted a Harley FL, so I decided on the Heritage.
I tried finding the right file from every source I know of, but no luck, so I got impatient and made my own.
I started with inkscape, but it was so full of nodes and other garbage that I just did an old fashioned trace.
So, if anyone else is facing the same dilemma, here ya go!
It took quite a while, but I think it should cut pretty good.
- Larry83301
Re: Heritage Classic
Looks very nice. Haven't opened it yet, so thanks for the picture to go with the file.
- John Frantum
I just noticed that there are a couple spots that need to be trimmed and I didn't round the corners on the heads.
I fixed my copy, but you might want to give it a once over prior to cutting.
- steel 35
Thanks for sharing.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Very nice thanks for sharing.
Thanks for the post John, It's a great file and I, along with the many others on here appreciate it. Thanks again.
- little blue choo
Good looking file John. Thanks for sharing it.
Rick
Rick
Rick
Arclight 9600 4x8 table
Thanks for sharing very detail
- John Frantum
I cut one out today, it looks pretty good, but I can't seem to upload a jpeg in the reply.
At any rate, there were a few issues, there's a line that needs to be deleted on the leading edge of the fork tubes at the front fender, also there's a trim needed on the gas cap.
I trimmed some lines, deleted some duplicates, joined the perimeter as a single entity, and created layers for perimeter, interior cuts, and the bend slots. Some of the detail (cylinder fins, etc) is still too small for my finecut kerf. These areas will need widened up at current scale (I changed it to 30" wide), or scaled up until the kerf can fit.
Great trace. Thank you very much.
- hdfaster
Great file. Used to have a heritage softtail. Now riding a Roadking. Thank you.
thanks nice file
