Tired of welcome signs?
- John Frantum
Someone told me that I have too many welcome signs, so I thought I'd mix it up a bit.
I haven't cut one yet, and there are some thin areas that need work, but here ya go.
I just added a picture of my finished product, but scroll down to check out Acourtjester's version.
Re: Tired of welcome signs?
That would be neat to do an outline and then cut the inside parts and attach them to the outline.
May be another thing on my To Do list
Thanks for posting
Thanks for posting
Here is my favorite! I have this at the end of my driveway.
The file came from this site.
CandCNC Electronic
Hypertherm Powermax1000
Mach 3
CorelDrawx5
LDR 4X8 table
Mach 3
CorelDrawx5
LDR 4X8 table
I believe this is the original post...from 2010! Where the hell does the time go!
Thanks ou812!!!
http://www.plasmaspider.com/viewtopic.p ... away#p9505
Thanks ou812!!!
CandCNC Electronic
Mach 3
CorelDrawx5
LDR 4X8 table
Mach 3
CorelDrawx5
LDR 4X8 table
- John Frantum
I cleaned it up a bit and added a few features, it still needs a few touch ups.
What software are you using I can open it in SheetCam but not in Inkscape or Irfanview
I would like to break it up and make the inside parts separate cuts nested together so I can make a 3D type plaque.
Could you post it in a SVG file
- John Frantum
I just use a cheap QCAD program at home, I usually use AutoCad/Striker to process them.
I just tried to export in SVG, but the line width goes crazy.
I'll try again later, have guests coming over tonight.
Thanks I will watch for it.
- John Frantum
I tried some more,and the line width is still distorted, but I will attach the SVG file, maybe you can find a way to fix it.
Thanks John
I can now open in Inkscape the SVG file and work with it.
have fun
Tom
have fun
Tom
Here is one we used to make......it was a good attention getter.
- John Frantum
Yep, that would get your attention!
Thanks for the share!
love it......would change the wording to NO SOLICITING VARMIT!!!
that's a really nice one Corel doesn't seem to want to open it
Greg From Storiesnsteel
Thank for sharing
I took John's sign idea and rearranged it somewhat and this is what I can up with.
I used "Loctite super glue" and some pieces stuck to fast placement could have been better and I should have made it bigger. I lost 3 small parts and had to cut the again today need to paint and install them soon
- John Frantum
Looks great Tom, good job!
thats awesome!!
Wow !
Hypertherm Powermax 85
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
