Beard and Buck
- John Frantum
Beard and Buck
Here's one you can play with, the beard gets way too thin, as do the turkey legs, but it's an easy fix.
There are 2 sizes provided, 11 1/2" & 15 1/2", I cut a couple of the 15 1/2" on a laser out of 18 ga. and they didn't come out too bad.
It definitely needs some clean up, have fun!
Re: Beard and Buck
Thanks!!
- John Frantum
Re: Beard and Buck
I revised the thin spots a bit, this should cut better.
Re: Beard and Buck
Awsome, thank you!
Re: Beard and Buck
Thanks for the share
Re: Beard and Buck
Thank you for the share
- david jordan
Re: Beard and Buck
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Re: Beard and Buck
Thanks,love it
Re: Beard and Buck
Thanks for sharing. Great
Re: Beard and Buck
Very nice deer, but it is blank when I try to open it with autocad 2002 edition
Re: Beard and Buck
Thanks anyway, got it open with inkscape with help from Larry
