eagle
eagle
Here is an eagle I traced today from a silhouette online. Hope it's useful to someone!
5x10 Dynatorch High Definition plasma table. Cuttingshop drawing program. Sigmanest nesting program. Custom fabrication and powder coating.
Whatsoever thy hand findeth to do, do it with thy might Ecclesiastes 9:10
Re: eagle
Maybe should check it over before you cut it as I haven't tried it out yet...
Re: eagle
Loaded in CAD everything looks cut ready.
Thanks for the post, GREAT JOB!
Re: eagle
Nice eagle thanks for sharing.
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
ArtCam
Sheet Cam
Mach3
Charlotte,NC
Re: eagle
Thanks for sharing.
- larrycameron44
Re: eagle
Thanks, nice file.
NZ
NZ
Re: eagle
That is a really great looking eagle. Thanks!
Re: eagle
Thank you! I like it!
Re: eagle
Thanks everyone. I've added some words to go with the eagle if you want it for the wall... Isaiah 40:31
Re: eagle
Very nicely done, Thanks for the share.
Mike
Mike
Re: eagle
Thanks for posting when I cut this I am going to do a layered look with the head in white and the beak in yellow and the tail in black. Placed on the overall brown base outline.
- steel 35
Re: eagle
acourtjester wrote:Thanks for posting when I cut this I am going to do a layered look with the head in white and the beak in yellow and the tail in black. Placed on the overall brown base outline.
Pictures; we need Pictures.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Re: eagle
Yes! I'd love to see how it turns out!...steel 35 wrote:acourtjester wrote:Thanks for posting when I cut this I am going to do a layered look with the head in white and the beak in yellow and the tail in black. Placed on the overall brown base outline.
Re: eagle
I cut it out today from 14 Ga it is about 18" across but think I should be about 24" to look better.
I was please with the fine cut and 200 IPM . I worked over the original drawing to remove think lines for a better cut.
I will post the colored version soon.
Re: eagle
finished pictures
Re: eagle
Very nice! That turned out beautifully... thanks for posting pictures!
- david jordan
Re: eagle
Do you glue on your second layer or do you spot or tack weld?
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Re: eagle
For this one I used Super Glue from Locktite, marked professional liquid found at a craft store.
I have used another glue called Goop that stays very flexible and works great for larger parts handling but is stringy.
Don't get that stuff on clothing it won't come off!!!
