Welder Business Card Holder
I made a bunch of these for a local welding supply company
Re: Welder Business Card Holder
Nice - I like the concept!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
- yeomansjon
That's great, thank you!
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
CNC Plasma Cutting
Plasmacam DHC
Very nice! Thanks for the file.........RK
Now that I have looked closely at the file I have to ask if you are using a laser cutter? Even with fine cut tips there is no way I could cut that close!
- steel 35
Russ K wrote:Very nice! Thanks for the file.........RK
How about this one then! Mine would have cut the first one twice. Thanks I like it.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Yes, all of my drawings are designed with the laser in mind.
Appreciate the share kaos2016, I'll be making a few of these for gifts.
nice work
- Zippo
Thanks for posting.
Very cool, thank you!
Jason
Jason
I tried cutting it on my plasma table with fine cut tips and most of the center just fell out. Too much detail for plasma but an awesome design for sure!
- steel 35
No change to drawing had to see; 220 IPM Fine tip.
Will give it one more try.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
I had the same problem I think it need a up-scale maybe 1.5 That would make the size about 7.5" X 12" long.
Thank you for the file.
Mtw fdu.
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Thanks for sharing
Very nice, I will post pic after I cut with waterjet
Omax 80X Waterjet 6 x 12 with Tilt-A-Jet
CamFive 150w Co2 Laser
Miller Mig & Tig
Whitney-Jenson 20 ton Punch Press
Atlas Lathe
Miller Mig & Tig
Atlas Lathe
Awesome
Thanks for sharing this. I cut one out that I scribed all the small welder stuff. I'll try to remember to take a picture.
Here it is scribed out.
Thanks for the file. Just starting a welding business and this will help a lot
Thanks for sharing
Thanks for the art. Huge help on a project I'm doing
If you decide to cut this one or something similar, please post a photo of your finished item. I am interested to see how it looks when bent up and painted.
