Bull head
- plasmajoe
Re: Bull head
I am not a 100% sure what a Brahman Bull is but there are few bull heads on the forum, just do a quick search you will find them.
Maybe put up a JPG of this bull.
- buzzedart
Re: Bull head
Full Bull & a bull head.
These may need some minor tweeks, but good luck.
buzzaedart - Got an idea? Let me steel it!
- ssderick
Re: Bull head
great art
thanks!
thanks!
- ssderick
Re: Bull head
buzzedart
started to work with your bull head but I need something that is not a wire frame if you understand that. this needs to be about a 30 inch circle with a brahman bull head. its going on a gate.
thanks
thanks
Re: Bull head
Whats wrong with buzzedart bull head? Looks great. Its 10 seconds from being ready to cut. It is in a ring. Scale it to 30" and Ta-Da! its ready to cut. If you want it solid, fill the space between the lines. Maybe I am missing something on this one.
- erichsmith
Re: Bull head
I had no problems modifying it. Took a few mins to get it adapted for how I would cut it but that is half the fun with this site. Take a concept, idea, or drawing and modify it for your use. Make it, post it, and let someone else run with it as well. We are all in this together and while I don't use plasma this site still has a wealth of information for water and laser guys as well.
Eric Smith
Hobart Champion
Miller ABP330
Miller 185, 212
Miller Spectrum 625
Miller Dialarc 250
Oxy/Fuel
MSC Mill
Atlas Lathe
Grizzly Mill/Lathe
Scars and 1 understanding wife, 1 uninterested 16yr old girl, 1 thinks daddys work is cool 3yr old son.
Hobart Champion
Miller ABP330
Miller 185, 212
Miller Spectrum 625
Miller Dialarc 250
Oxy/Fuel
MSC Mill
Atlas Lathe
Grizzly Mill/Lathe
- ssderick
Re: Bull head
Its not me its the customer, when its cut out it is to thin
Re: Bull head
What cutting software do you use. Is the basic design posted above what you are looking for or are you looking for something totally different? If the drawing above is too detailed you should be able to go into your cutting software and delete out some of the detail. I use PlasmaCam and it is simple to edit drawings. Are you wanting a more solid cut out without as much detail? Let us know what cutting software you use and what editing software you have such as AutoCad or Corel and I am sure somebody here can help you edit the drawing.
Danny
Danny
- Larry83301
Re: Bull head
See if this is more like what you want. I work in wood, and I must modify most of the art to keep from just falling apart when I cut them.
- Larry83301
Re: Bull head
Attached pic.
Re: Bull head
Thanks Larry. I guess he can't see it is the same file. He must think you cut on both sides of a line and not on the line (or on one side). I enjoy helping but this one is so simple.
Re: Bull head
thanks Larry for your kindness
- Larry83301
Re: Bull head
Glad to help. I get a lot of great ideas from this site, happy to return the favor.
- ssderick
Re: Bull head
sorry guys, I am new to this stuff. I finally figured it out. IT will be a solid cut out, Ibroke the lines so pieces would not fall out so they will just be lines cut ine the plate for detail, hope ya'll can understand that. it took me hours. I have Torchmate Cad. I have used Autocad since the DOS days, but need to learn how to edit art work withit. There has to be some way to do this faster, as I said I am a Newbie.
Thanks again this site is GREAT
Derick
Derick
- plasmajoe
Re: Bull head
Derick, if you used AutoCad since the DOS days as have I, you can import the DXF into cad do your editing on it and WBLOCK into a DXF again and import into your torchmate software, it work just great, that is what I do also. I find AutoCad works the best for me, that is only because it is all I use. It will take time and training to use new software, as for anything for that matter. Also I find when you draw into AutoCad it makes a lot less nodes than other software out there, les nodes = smoother runing machine + nicer cuts. Have fun and keep on learning, this is lots of fun.ssderick wrote:sorry guys, I am new to this stuff. I finally figured it out. IT will be a solid cut out, Ibroke the lines so pieces would not fall out so they will just be lines cut ine the plate for detail, hope ya'll can understand that. it took me hours. I have Torchmate Cad. I have used Autocad since the DOS days, but need to learn how to edit art work withit. There has to be some way to do this faster, as I said I am a Newbie.
Derick
Re: Bull head
Hi Buzzedart, is it possible to get the full bull dxf file? Thx.buzzedart wrote:Full Bull & a bull head.
Re: Bull head
has anyone have the dxf?
- david jordan
Re: Bull head
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
- Larry83301
Re: Bull head
I think it is still in the upper part of this thread, but if not here is the one I did.Jowie wrote:has anyone have the dxf?
Re: Bull head
Thanks Larry, But would you have the full bull?Larry83301 wrote:I think it is still in the upper part of this thread, but if not here is the one I did.Jowie wrote:has anyone have the dxf?
- Larry83301
Re: Bull head
This is the one on top in the first post. Thanks to the original poster! Be aware that this is not cuttable, but here is the whole bull file that was posted.
