Axle Trusses
Axle Trusses
anyone cut any axle trusses or rear end bolt cover rings
I am working on a file right now let me know what yall think when I post
ABLE CUTTING & FABRICATION
torchmate 4800
BATON ROUGE, LA
torchmate 4800
BATON ROUGE, LA
Re: axle trusses
I've got some 14 bolt stuff...also have some of the more common rearend cover patterns
Re: axle trusses
I just got done cutting a truss for a dana 60 not sure if I like it I will post
let me know what you guys think
I am thinking I want it more tight fit to the axle housing
torchmate 4800
BATON ROUGE, LA
torchmate 4800
BATON ROUGE, LA
Re: axle trusses
dana 60 cover bolt pattern
torchmate 4800
BATON ROUGE, LA
torchmate 4800
BATON ROUGE, LA
Re: axle trusses
Toyota truss
ford dana 60 truss
thanks Kevin H
ford dana 60 truss
thanks Kevin H
5x10 Flow Waterjet
Re: axle trusses
14 bolt truss
Re: axle trusses
Does anyone have a pattern for a Chevy D 44 front truss
Re: axle trusses
Does anyone have a Dana30 truss? Looking for one for a Jeep! Thanks
Re: axle trusses
I am looking for the same file. If I find it I will let you know.
Re: axle trusses
Thanks for the files!!!!
Re: axle trusses
Messer MetalMaster Evolution
5-Axis Bevel-R Rotator
10'x25'
10'x25'
- Boneyard Welding & Fab
Re: axle trusses
Dana 30 truss
Boneyard Welding and Fabrication
Guysville, Ohio
Plasmacam DHC2 4x4
Everlast Power MTS 221STi
Hobart Champion Elite 11000
Hobart Handler 140
Hobart AirForce 250ci
Lincoln AC225
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Re: axle trusses
No idea why that double posted. Thats a file I found on here by another, I take no credit for it.
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Re: axle trusses
On every Jeep forum I am on, this would be the point where everyone asked why anyone would waste the steel on making a truss for a Dana 30 (Turdy)... LOL
Click here for build post
Re: axle trusses
Thanks for the file.
Re: axle trusses
Lots of jeeps I go wheeling with are still running the Dana 30 axle, Is it a great option? No. But some guys don't always have the extra cash to swap axles, so upgrading the stock 30 is a low buck option.
I swapped my TJ to dana 44's front and back, so I don't worry about having a dana 30. But I will make and sell things for them because they're still a lot of them out there.
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Re: axle trusses
would you guys happen to have a truss file for 8.8?
Re: axle trusses
No, I currently do not have a file for the 8.8 axle. Although this could be something I find myself working on in the near future,
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Re: axle trusses
hey guys in still looking for a front dana 44 truss file, if anyone can help me I would greatly appreciate it.
Re: axle trusses
thanks for the share
Re: axle trusses
Anyone got a superduty 60 truss? thanks for the share
Re: axle trusses
Anyone have a file for D60 front diff cover?
Re: axle trusses
Yeah Id like a 44 front drivers side drop truss. Ill end up making one.
- _jay_
Re: axle trusses
Tnx for the dana 30 struss.... can it be used for a 44 ?
The learning curve is exponential AKA "never ends " !
Re: axle trusses
The Dana 30 truss could possibly be used on a Dana 44 with modification. It won't be just a simple weld on fix, but I don't see why I couldn't be made to work with some effort.
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
Guysville, Ohio
Plasmacam DHC2 4x4
Hobart Handler 140
Lincoln AC225
