Fox Run
Fox Run
Can someone please help trace this pic ive tried corel draw with no luck
Re: Fox Run
quick trace but need higher res file to get better trace, hope this helps
Re: Fox Run
Thanks alot better than my trace
Terry
Terry
Re: Fox Run
Try this. I also attached the vector PDF if you want to work with that. The DXF was a quick export from Illustrator, I haven't check it in my CAD software to be sure its cut ready.
