Help with Trace
Terry
Help with Trace
Post by Terry »
Been trying to trace this with Corel no luck any help would be appreciated
Terry
Gamelord
4.5 Star Member
4.5 Star Member
Re: Help with Trace
Post by Gamelord »
Terry, the image is too small to really do anything with it so if you have a larger image, try this.
Open the image in Corel Photopaint (NOT DRAW) then convert the image to a 1 bit color black and white drawing, make sure it is line art and not halftone or any of the other selections. This will remove all the color and replace it with a solid black and white drawing. Basically it will remove the green and brown and if there is any gradients, it will change those to solid black as well.
Once done you can then copy the image and past it into a new blank document in Corel DRAW. Once there, use the trace function to trace the image. You should get a pretty good trace from it now. Once traced, edit as needed. let me know how that goes for you and if you have any problems.
Hope this helps.
Torchmate CAD
sbest1
Re: Help with Trace
Post by sbest1 »
Here is a start, but not ready to cut. I have included a bmp and dxf as well as the original blown up, of the picture for you to work with
