Self Locking Latch w/ Padlock Capabilities
KIDTech
Post by KIDTech »
Here is a change I made to a latch I got from this site that I altered for my entry gate builds. What I added was the ability to lock the latch with a padlock, on the bottom bracket it would be the second hole from left to right which when the latch is closed one could loop the lock through all three holes. I will try to remember to post pictures of the gate latch when I get a chance, I have a gate at p coat now so whenever it is done. Thanks for the original file.
The link to the original is: *There is a picture in this thread that shows how it is to be laid out.
http://www.plasmaspider.com/viewtopic.p ... tch#p13762
LockingLatch.dxf
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
timberfab
Re: Self Locking Latch w/ Padlock Capabilities
Post by timberfab »
Awesome !
james.davis
Post by james.davis »
Thanks I'll be using that :)
Jim
Mtw fdu
Post by Mtw fdu »
Thanks for the file.
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
KIDTech
Post by KIDTech »
I said I would post an image of how it looks with the lock and here it is. Don't mind the shovel handle and the spring is not attached to the bottom hole yet but honestly when it is placed this way you do not need the spring.
Gecko g540
Proma THC
Millermatic 211
plsmatech
Post by plsmatech »
Download broken
File does not open
larrycameron44
Post by larrycameron44 »
plsmatech wrote:Download broken
File does not open
I downloaded today and cut and all worked fine.
Motoxrdr
Post by Motoxrdr »
modified this a bit and made it to accept a 1" roundbar to use as a latch on a tilt deck trailer. also made it to where a pin can lock it in the open position, and the very bottom hole towards the outside of the base tab is for a piece of 1/2" round bar to get welded into as a stopper for the middle piece of the latch and to keep the sides spaced properly.
1 inch gravity latch.dxf
Bodyofametallurgist
Post by Bodyofametallurgist »
thank you
jason.jason.p
Post by jason.jason.p »
Thanks for the share
