I started doing that and adding a set of stickers that I made only as sticker.Excuse my English
Yorkshire Terrie
- JD770
Yorkshire Terrie
Re: Yorkshire Terrie
That's cute! Thanks for sharing
- JD770
Cutting sheets 2 mm 300x420mm
i can not get the file to open??????? thanks. CG
There is plenty of room at the top - and the top is where you want to be. Whenever you do a project - do the hardest part first and the rest will be easy.
- Larry83301
Try this one. Hope it works for you.anvilhead wrote:i can not get the file to open??????? thanks. CG
That's pretty impressive, nice work.
Mike
Mike
