Moto Skeleton
Moto Skeleton
Hey everybody. Here is a DXF file that I cut out for a customer's motorcycle shop. Bryant Henry converted this file for me and did an AWESOME job. Here is his email if you are interested in his work. idahobry at yahoo.com
- plasmajoe
Re: Moto Skeleton
nice file Thanks for sharing.
Re: Moto Skeleton
Nice work Joey.
Re: Moto Skeleton
JoeyD, I would like to personally thank you for sharing your Moto Skeleton file. I have cut several of these out, with modifications, for the motorcycle fraternity in the Seattle/Tacoma area. Something about it clicks with those crazy two wheelers! Thanks again and tell your Designer that he does great work.............Russ K.
Re: Moto Skeleton
You're very welcome, Russ! Bryant Henry did the conversion for me and I think it turned out great!
Re: Moto Skeleton
nice work!! this will look good hanging in my shop.
Re: Moto Skeleton
has this file been cut if so was the file cut as posted
Re: Moto Skeleton
Yes, this file was cut. I only posted the drawing not the cut paths. I use a Plasmacam and it turns out great!
Re: Moto Skeleton
I understand .great file thanks abunch
Re: Moto Skeleton
nodes need connected on file
- ColoradoWayne
Re: Moto Skeleton
I think there is a significant difference between what Plasmacam uses and what Sheetcam and Autocad can use. Lots of problems with the file for me, open nodes where the lead ins were and corners that crossed themselves. But it is a really cool design so I played with it for a while. Not sure I caught everything, but for those of you not using plasmacam take a look at this file, it may work a little better for you? I never was able to connect the lines, not sure what that is about.
JoeyD, thanks for the file - it is a very cool design. I will use it, for sure! Keep up the good work.
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
- steel 35
Re: Moto Skeleton
ColoradoWayne wrote:I think there is a significant difference between what Plasmacam uses and what Sheetcam and Autocad can use. Lots of problems with the file for me, open nodes where the lead ins were and corners that crossed themselves. But it is a really cool design so I played with it for a while. Not sure I caught everything, but for those of you not using plasmacam take a look at this file, it may work a little better for you? I never was able to connect the lines, not sure what that is about.
I connected a few extra starts and joined your layers, Sheetcam likes this one a little better thanks for the great start.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- ColoradoWayne
Re: Moto Skeleton
Joined layers - that is probably why I could not join the lines. How do you join layers?
Wayne
- steel 35
Re: Moto Skeleton
I opened your file after playing with the first one and you made it way past me on rounding the edges! When opened in sheetcam there were 4 layers, I cheated and opened it in a Vcarve / Corel style program, selected all and clicked Join, there are almost 1000. Another trick I learned on this fabulous site.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
- ColoradoWayne
Re: Moto Skeleton
I think we are all always looking for little tricks to improve the process or the work. Thanks for sharing.
Wayne
Re: Moto Skeleton
when I open this file all the nodes are not connected can anyone help with this I'm using corel draw thanks so much
- Cz_apie
Re: Moto Skeleton
p m metals wrote:when I open this file all the nodes are not connected can anyone help with this I'm using corel draw thanks so much
p m metals
Try this one, all connected in plasmacam and exported as DXF
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
