Need help-tracing problem-Bird House Numbers
I traced a jpeg I got online. Afterwards I chose the outline to object fcn and now when I import into sheet cam I have 2 lines around the drawing. Like a double image. How do I get rid of that? Please explain so I can correct it and know what to do next time.
Re: Need help-tracing problem
http://www.plasmaspider.com/download/fi ... w&id=36498
If you enlarge the work you'll see where the two lines over lap each other . Break each side of the over lap delete one of lines and reconnect the remaining line.
Jim
Jim
Re: Need help-tracing problem-Bird House Numbers
Nice grouping of birds thanks for sharing!
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
ArtCam
Sheet Cam
Mach3
Charlotte,NC
I hope this helps?
I see where the two lines overlap. I broke the nodes and reconnected. I still have the other line. Do I have to manually delete each segment? Any quicker way to chose the line and remove in one click?
