I have to make 35 of these 'trophies' for a big car/bike/truck show in our area. I'd like to be as efficient as possible with this (obviously) and when i try to fit as many as I can on 1 4x4 sheet. I can arrange to fit 10 on 1 piece, leaving me needing 4 sheets, but does anyone out there see that they could use nesting software and find a configuration that will fit 11 or 12 on 1 4'x4' sheet? Any help would be appreciated, thanks![attachment=0]Opp_Works_Trophy_R0_pcm.pcm
Nesting Help-Trophies
- yeomansjon
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
www.facebook.com/fastjonnycustomdesign
CNC Plasma Cutting
Plasmacam DHC
- rdj357
Re: Nesting Help
10 is as good as I can get on a 4x4 using NestMaster.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Re: Nesting Help
If you set it out to cut 8x4 and index your sheet this was 5 minutes roughly laying them out to get 22, a bit of messing around and you'll probably get more.
Murray
Murray
- ou812
Re: Nesting Help-Trophies
4x4
- yeomansjon
Thanks Guys, I appreciate it! I can probably index an 8' sheet no problem.
CNC Plasma Cutting
Plasmacam DHC
CNC Plasma Cutting
Plasmacam DHC
