i need some letters fit to an arc if some one could help me with this would be great!!!!
thanks jake
help getting letters to an arc
Re: help getting letters to an arc
Not for sure if you have CorelDraw or not, but here is something that I came up with. I don't have the dxf tool on this computer. This should get you going - -
G
G
if you could do that in a dxf that would be great i dont have corel yet.
thanks jake
thanks jake
Is this what you are after? I have used Arial Bold and I haven't welded the text to the circle so you could separate if you wanted to.
Murray
Murray
Here is a free way to do it with paint.net this video tell of a Plug-in you will need to add to paint for text work.
one thing I found very handy is to do reverse directions so you can start at 9 o-clock and have the top go CW and then the bottom go CCW. This operation is done with out any other thing on th epage not like the demo. When you open the text tool move the menu from the center of the screen so you can see where the text is placed. That is done in 2 operations but you save it in jpeg then import to Inkscape and convert to path and DXF or SVG for cutting
https://www.youtube.com/watch?v=HM2QSncYpTE
here is the plug in download location
http://paint.net.amihotornot.com.au/Fea ... ormations/
when you download the they need to be moved to C:\Program Files\Paint.NET\Effects
you may need to download each text effects for you to have all of them.
a better font would make it look better but this is similar to what you can do for free
Here ya go. You may have to adjust the spacing on the bottom wording.
Last edited by MetalTorcher on Fri Feb 06, 2015 11:44 pm, edited 2 times in total.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
- greenweanie
Here's a nice free program...
http://www.deskam.com/deskengrave.html
that would be great if you could put the outfitters curved too metal torcher!!!
and thanks to all for the help!!!
I use deskengrave alot
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
