It is currently Wed Jan 17, 2018 1:55 am
Lotus scroll work
Metal-Madness
Lotus scroll work
Postby Metal-Madness » Mon Feb 08, 2010 8:58 pm
My wife wants me to make this for her, can anyone convert this for me ???
MQUICK
Re: Lotus scroll work
Postby MQUICK » Tue Feb 09, 2010 4:54 pm
Try this.
Could not get the photo to upload.
Mike
scroll grill.dxf
admin
Site Admin
Postby admin » Tue Feb 09, 2010 5:08 pm
Wow. Good stuff Mike. Looks fantastic and I added a sample image for you.
Admin
DumOleBob
Postby DumOleBob » Tue Feb 09, 2010 5:52 pm
Mquick - How'd ya do dat so fast!? You didn't use that photo - did you? Amazing! :lol:
MQUICK
Postby MQUICK » Tue Feb 09, 2010 6:03 pm
Thanks for posting the pic. I never can get that to work. I drew the whole thing. I dont mind posting and helping and drawings. I use the site alot and give back when I can. I shifted the pattern so here is one the matches the Photo layout.
Mike
scroll grill 2.dxf
DumOleBob
Postby DumOleBob » Tue Feb 09, 2010 6:16 pm
I officially appoint you as ?DA MAN?! That drawing took one heck of a lot of work and my hat is off to you!
Here is a simple fire screen frame I drew up so I know how much work is involved! The problem with it is there is so much warping resulting from the heat. I guess a guy could cut it one little seg at a time and allow for cooling.
Maybe someone will play with it and come up with a better idea?
Fire Screens.dxf
Loyd
Postby Loyd » Tue Feb 09, 2010 6:39 pm
Mike, I don't know how you do that so well....my hat is off to you. Great job!!
Loyd
DumOleBob
Postby DumOleBob » Tue Feb 09, 2010 6:42 pm
I should add I was going to use something to simulate rivets in all those the small holes, but never got around to it. Then attach fire screening across the frame. Maybe one day....? :?
Loyd
Postby Loyd » Tue Feb 09, 2010 7:02 pm
That would look good. We use a type of rivet to attach our ID plates on our reels that would work great for that. They are called
drive screws. They have a type of knurl on them and you drill a pilot hole and drive them in with a hammer that would look really
good on that screen.
Loyd
http://www.mcmaster.com/#drive-screws/=5qyaer
Metal-Madness
Postby Metal-Madness » Tue Feb 09, 2010 10:10 pm
Thanks ALOT..... I cut it out tonight i was so excited...
Loyd
Postby Loyd » Wed Feb 10, 2010 12:32 pm
Boy!, you didn't waste any time. That looks good......looks like some brownie points from the wife are in order............
Loyd
DumOleBob
Postby DumOleBob » Wed Feb 10, 2010 2:56 pm
Hi Lloyd - I can't find those drive screws. Can you be more specific as to exactly what they are called or what the stock number is ?
Great idea! Thanks
Loyd wrote:That would look good. We use a type of rivet to attach our ID plates on our reels that would work great for that. They are called
Loyd
Loyd
Postby Loyd » Wed Feb 10, 2010 6:29 pm
This product matches all of your selections.
Part Number: 90081A144
$2.85 per Pack of 100
Nail Type
Easy-Drive
Easy-Drive Nail Type
For Sheet Metal, Plastic, and Plywood
Material
Steel
Finish/Coating
Zinc-Plated
Decimal Size
.140"
Number Size
No. 6
Head Type
Oval
Shank Type
Spiral
Head Diameter
.260"
Head Height
.103"
Recommended Hole Size (Drill No.)
.120" (31)
Length
1/4"
Box Quantity
100
Specifications Met
Not Rated
Note
Length is measured from under the head.
I think that one would look good on your design. You have a great idea there. McMaster-Carr has a great selection of screen also.
Loyd
mayper
Postby mayper » Thu Dec 27, 2012 4:34 am
Thanks for sharing what a great design
Aird
Postby Aird » Thu Dec 27, 2012 1:37 pm
Thanks, Works like a charm as a cold air return.
Aird
lucky7sg
Postby lucky7sg » Tue Sep 19, 2017 7:10 pm
Fantastic work. Thankyou
BILLETMAN
Postby BILLETMAN » Wed Sep 20, 2017 4:38 pm
great work MQUICK thank you!!!
Users browsing this forum: Google Adsense [Bot], Google [Bot], reklez2010, suity13 and 14 guests
