It is currently Mon Jul 23, 2018 4:06 am
Wildlife Scenery Firepit
Scheub
Postby Scheub » Fri Feb 14, 2014 9:51 pm
Here is a firepit that some first-year welding students built. Pretty good projects for beginning welders. Can't really screw them up too bad!! ;) Anyways, a thanks goes out to thissideup for the design of the firepit, and SignTorch and Jason @ freedxf.com for the deer, duck, bear, and turkey scenes.
In the .dxf file, there is a five-sided piece that we cut out to serve as a bending guide for the sides (angle was 145 degrees between sides and feet). The notch should be towards the top side. There are bootrail supports included that should match up to the angle of the sides, as well.
**may want to cut and build the sides of pit before cutting out the bottom to insure proper fit. After bending with rosebud, our bottom didn't fit quite as snuggly as intended.
blank_wildlife_firepit.zip
thissideup
Re: Wildlife Scenery Firepit
Postby thissideup » Fri Feb 14, 2014 10:15 pm
That looks awesome!
Zippo
Postby Zippo » Sat Feb 15, 2014 11:44 pm
Thanks for posting.
HammerDownJustin
Postby HammerDownJustin » Tue Feb 18, 2014 1:56 am
Looks good and guessing you got the table back up..holler at me before that student cuts that bender please.
Miller 251 Mig
Metal Storm
Postby Metal Storm » Tue Feb 18, 2014 11:43 pm
thanks for the share. this one is just the size I was looking for. I want to build one of the big monsters but do not have the shop space yet. still getting organized.
Metal Storm
by J.P. Janeway
[email protected]
Plasma Cam DHC2
Thermal Dynamics Cutmaster 38
bnechak
Postby bnechak » Sun Mar 02, 2014 11:22 pm
Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
Scheub
Postby Scheub » Wed Mar 05, 2014 4:47 pm
bnechak wrote:Hi guys new at this. Awesome pit. What thickness are you using to cut this out of (1/8 in plate)?
That pit is 3/16". 1/8" would probably work fine for a fire pit, however. I am tempted to build a few and see how they withstand the heat. Definitely would be a little cheaper.
cdbradbury
Postby cdbradbury » Fri Mar 07, 2014 3:30 pm
Did you just heat and bend the bottoms or use a break?
Scheub
Postby Scheub » Mon Mar 10, 2014 2:24 pm
We heated them with a rosebud torch. Wasn't too bad, but a brake would be a lot faster for sure. In the file, I drew a little angle gauge that we cut out and used to be sure it is bent to the correct angle, which worked pretty well. The half circle cut-out on the top of the angle gauge goes towards the top.
Barnett_9437
Postby Barnett_9437 » Fri Apr 04, 2014 8:33 pm
Alright, Someone help me to know where the boot rail straps are positioned. Thanks in advance
Scheub
Postby Scheub » Mon Apr 07, 2014 9:40 am
Barnett_9437 wrote:Alright, Someone help me to know where the boot rail straps are positioned. Thanks in advance
There is really no set position for the boot rail straps, other than we welded them flush to the top of the sides. I want to say we put them about 2" in from the corners, as well.
Barnett_9437
Postby Barnett_9437 » Mon Apr 07, 2014 12:18 pm
Thanks for the reply. That helps
Fordgal
Postby Fordgal » Wed Apr 30, 2014 12:16 pm
Thanks for the design!
CNCCAJUN
Postby CNCCAJUN » Wed Apr 30, 2014 2:02 pm
Thank you . . . very nice . . .
OK, I admit I am puzzle challenged . . .
Where do the (8) little pieces go?
I'm thinking somehow they support the bottom.
I looked at the picture and I am stumped. . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Scheub
Postby Scheub » Wed Apr 30, 2014 10:27 pm
CNCCAJUN wrote:Thank you . . . very nice . . .
The 8 small pieces are supports for a boot rail... Just realized that I didn't include any pictures with the boot rail so I understand the confusion. We place them flush to top of the pit (2 per side), longer side facing down, and the add some thin-walled square tubing as a boot rail. The random 5-sided piece is used as a bend guide when bending the sides; just heat and bend to match the angle.
prophetproducts
Postby prophetproducts » Wed May 07, 2014 7:41 pm
That's awesome! Thanks! What type and thickness of metal do you recommend?
Scheub
Postby Scheub » Thu May 08, 2014 9:44 am
prophetproducts wrote:That's awesome! Thanks! What type and thickness of metal do you recommend?
I use 3/16" thick mild steel. 3/16" seems to be thick enough to not warp or rust through too bad, but light enough to not make the pit too terribly heavy. The wildlife pit was designed to be able to fit two pits on one 4' x 8' sheet.
RGR
Postby RGR » Mon May 12, 2014 12:48 am
Well Done!
7012
Postby 7012 » Wed May 14, 2014 9:31 am
i love this pit design and how customizable it is. one quick question though, if i scale up the base plate to 18"x18" will everything line up correctly?
crazy59860
Postby crazy59860 » Thu Jun 05, 2014 1:30 pm
This is awesome........wish I would have seen this before we DUG a firepit.....now we have to redo to make sure grandkids don't fall in.
Great job.!!!
Toni
kangy
Postby kangy » Thu Jun 12, 2014 12:49 am
Great file, thanks for the share.
Pat
grovesmetal
Postby grovesmetal » Tue Jul 29, 2014 4:39 pm
I keep getting line 10 code error, please help. Great pc. ,would look good where my wife's bird bath was. THANKS
Tdorn44
Postby Tdorn44 » Tue Oct 28, 2014 2:02 pm
Very nice cant wait to cut this out
bnbmotorsports
Postby bnbmotorsports » Wed Nov 19, 2014 4:10 pm
Thank you very much for the file! We are dirt track racers so modified it just a bit to show our car number.. :) turned out really nice!
LakeCruiser
Postby LakeCruiser » Thu Nov 20, 2014 11:00 am
Here's mine. A hunting theme.
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Users browsing this forum: Google [Bot], jackleg007 and 14 guests
