Need Help with picture
kthorpe88
Post by kthorpe88 »
I have tried and tried in both flexsignpro and coreldraw6 and can't get a good trace with this file! I'm sure I'm just doing something stupid but if someone can get a trace and let me know the steps they took?
MetalheadRK
Re: Need Help with picture
Post by MetalheadRK »
I would try Inkscape. I use it all the time and have pretty good luck with it.
Kemarie
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Chopper John
Post by Chopper John »
This is all I had time for, maybe you can handle the lettering or someone else can give you a hand.
Chopper John
Mad City Cycles, Inc.
kthorpe88
Post by kthorpe88 »
Chopper John,
Thanks for the crown part! Now how did you trace that? What program and steps did you take? I also downloaded and tried Inkscape and had no luck with that. When I try to trace things I always get just horrible lines and half the letters.
Also I have no problem doing the rest but am new to this and don't know where you guys get your font or how you guys personalize stuff with letters. I can only make fonts that are lines not block letters unless I draw out all the letters using autocad and that would take way too long!!!
Chopper John
You are welcome. I loaded the picture into Autocad and did a manual trace of one half then I mirrored it. I've never had much luck with any type of auto trace so I do most things by hand. If i tried to explain the steps this would turn into a very long post and I suck at explaining things. As for fonts, I have had some good luck with a site called dafont.com and I think Signtorch offers some in dxf.
Chopper John
