A present for your supplier-Business Card Base
camjeep3
Re: A present for your supplier-Business Card Base
Post by camjeep3 »
how are you guys downloading a DXF. file and editing it? I have ran across this a few times. Id like to personalize this file for my biz. any ideas? I use inkscape and solid works 2d.
Old Iron
Post by Old Iron »
Download the file then import it to Inkscape to do your editing
camjeep3
Post by camjeep3 »
for some reason this file wont do that for me... I tried a few others and it worked... Thanks!
tumbleweed
Post by tumbleweed »
I would like to ask Art & Fire what font he used on the word "Linde". It looks like it would cut very nice. Thanks in advance.
LDR 4x8 Water Table
Hypertherm 65 Machine Torch
Sheet Cam
Mach 3
art&fire
Post by art&fire »
Sorry for the late reply.
I did not use a font for the name Linde. It is actually a trace of their company logo.
weldcutbend
Post by weldcutbend »
Thanks for the file. It cut just lovely...
camjeep3 wrote:for some reason this file wont do that for me... I tried a few others and it worked... Thanks!
See if this will open for you, OK :D :D
BUSINESS_CARD_HOLDER FIVE POINTS RX -1.DXF
Wasn't sure if that was the one you wanted, just went back and loaded the last DXF, if it's a different one you want just let me know, but open this one first and see if that works for you.
Rex
Post by Rex »
Hypertherm 65
csplazma1
Post by csplazma1 »
Did this yesterday just to see how the bends would work out. Used 14 gauge and escalade white powder coat from Prismatic powders.
C&S PlaZma Metal Works
LDR Motion Systems 4X8 Water Bladder
Hypertherm Powermax 85 Machine Torch
Everlast PowerPlasma 60 Handheld Torch
Thunder Laser NOVA 51
wickedpig
Post by wickedpig »
thanks for the file
AM_I_Missing
Post by AM_I_Missing »
Capstone wrote:This has been a great way to use up some scrap 16ga.
Some of you might go to ARC3 for your welding supplies, so please make one for your local supplier too. If you see one already on the counter, you'll know it was from here. :)
ARC3 2-Place Business Card holder.svg
Could someone please reach out I'd love to use this file but I don't have the talent to replace it with my logo.
Here is how to do it so you know next time. Download Capstone's file then in Inkscape using the node tool remove adjacent nodes to disconnect the top from the bottom then remove all top nodes, and then connect the top nodes to form a line at the top. see images below.
Then add your logo and attach it by just connection the two drawings and use the union tool under path highlight one by holding down the shift key then the other.
AM_I_Missing
Eggman wrote:Here's my version.
Could I have this cut file or a 6 card holder?
Ken Marple
Post by Ken Marple »
thanks, looks great,
MrsSavage
Post by MrsSavage »
This is great! Thank you for sharing!!
Strawboss
Post by Strawboss »
Thanks for the share
Joshwelder123
Post by Joshwelder123 »
Whhere can i get this download?
Joshwelder123 wrote:Whhere can i get this download?
Go to the first page of this thread for the dxf :D
recon44095
Post by recon44095 »
4X4 Plasma Cam DHC2
w/down draft Hypertherm 45
3x4x6 home made powder coating oven
Thachad15
Post by Thachad15 »
Thanks for the Share!
