sheetcam rotating parts
farmer53
Post by farmer53 »
HI
I have sheetcam TNG version 3.0.9
Is there any way to rotate parts on the screen instead of typing in the degree at the bottom of the screen. In searching online I found info on using the shift and < > keys but that only moves the part side to side or up and down.
Is there any way to rotate parts in mach3 or does it only understand the x and y location it gets from a cam ( gcode ) file.
THANKS
farmer53
srp
Re: sheetcam rotating parts
Post by srp »
Select the Nesting function.
Right click mouse
Select Grid Options
Set angle (Incerement of rotation)
Under the Angle + key Highlight and enter the Function key you wish to use to rotate the part in a + direction
Under the Angle - key Highlight and enter the function key you wish to use to rotate the part in a - direction
Hope this works for you - John
farmer53
Post by farmer53 »
THANKS John
That was exactly what I was trying to figure out.
farmer53 ( Don )
Return to “SheetCam”
