It is currently Wed Sep 26, 2018 3:05 am
Cannot connect to update server error
Post your questions or tips on SheetCam software in this topic.
edclayton1
Postby edclayton1 » Fri Mar 02, 2018 4:09 pm
Anyone know why most of the time I cannot use the SheetCam update feature. Attached is the dialog message that I get when I try to update my SheetCam. Then once in a while when I simply open SheetCam it decides it wants to do an update. Otherwise how can I update my system without losing all my settings is another question I would like to ask? Especially if that computer is not connected onto the internet. :o
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
djreiswig
Re: Cannot connect to update server error
Postby djreiswig » Fri Mar 02, 2018 9:07 pm
Just download the file from the site and install it. I've done this a few times on my non-internet connected computer and it doesn't lose the settings.
edclayton1
Postby edclayton1 » Fri Mar 02, 2018 10:04 pm
Thanks I will give it a shot now. I appreciate the info. Cheers,
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
tcaudle
Postby tcaudle » Sun Mar 04, 2018 2:40 pm
Down load to memory stick and copy file to SheetCAM PC unzip and run the installer. It sees older versions and does not change the settings.
If its a LINUX system follow the instructions on the ShhetCAM downloads page for the Linux version. You can also get details on the CandCNC Support Forum.
Return to “SheetCam”
